I am doing this project that is due in the next few hours. Basically, I have a photoresistor to detect the light level, and two motors that are controlled by two external 4-battery power supplies that are supposed to turn if the light goes below a certain level. The two motors are being controlled by using a 2n3904 transistor with its base connected to a PWM pin on the Arduino. Using analogWrite(), I am varying the speed of the motor.
I have a common ground between all of the power supplies. Not sure if the problem is the fact that I have a buck upconverter between one of the batteries and the powersupply. But the negative is connected to the common ground.
So basically, only PWN 6 works. None of the other PWN pins are working.
int photo_resistor = A0;
int motor_1 = 6;
int motor_2 = 3;
int val =0;
pinMode(motor_1,OUTPUT);
pinMode(motor_2,OUTPUT);
val=analogRead(photo_resistor);
Serial.println(val);
if(val<600)
analogWrite(motor_1,255);
analogWrite(motor_2,255);
analogWrite(motor_1,0);
analogWrite(motor_2,0);
Please help!
