Arduino Uno Project Help
Hey guys, I needed some help with a project (miniature garage door entry and park assist project). I'm a beginner here with stuff related to Arduino's and electronics in general. I was working on a project where I have a servo, led display(16X2), rfid scanner, ultrasonic sensors (2), and a buzzer attached to my arduino uno r3. I'm trying to do 2 things, detect the distance of an object (using one of the ultrasonic sensors) and if less than a particular value then run the servo to go to 180, along with that, detect a particular rfid card and do the same thing with the servo. And after a delay, make the servo go back to 0. At the same time, the other ultrasonic sensor is to detect if the object gets too close and displays text on the LED display (16X2) and get the buzzer to buzz. This was the plan, but if i connect all of this up, i dont think there's any power reaching the servo at all. I directly powered all this up with the arduino connected to my laptop. But nothing was working. Only the Rfid had power because it was directly connected to the 3.3v point on the arduino. I've been completely stopped dead in my tracks here, not able to figure out what to do. Please help
The RFID gets connected to the rest of the ports on it.
Code for it:
#include <Servo.h>
#include <MFRC522.h>
#include <SPI.h>
#define RST_PIN 9
#define SS_PIN  10
#define threshold 50
MFRC522 rfid(SS_PIN, RST_PIN);
String Mastertag = "D3 11 77 A9"; // Enter you tag UID which we get it from first code.
String UIDcard = "";
LiquidCrystal_I2C lcd(0x27, 16, 2);
int servoPosition = 0;
int led = 8;
// Remember buzzer = A3
int switcher = 2;
const int trig1 = 3;
const int echo1 = 4;
const int trig2 = 7;
const int echo2 = 6;
Servo myservo;
int switch_state;
long duration; // Duration for sensor 1
long duration2; // Duration for sensor 2
int distance; // Distance for sensor 1
int distance2; // Distance for sensor 2
bool isObjectDetected; // Flag for object detection
  SPI.begin();
  rfid.PCD_Init();
  lcd.init();
  lcd.backlight();
  lcd.clear();
  myservo.attach(5);
  myservo.write(10);
  pinMode(switcher, INPUT);
  pinMode(trig1, OUTPUT);
  pinMode(echo1, INPUT);
  pinMode(trig2, OUTPUT);
  pinMode(echo2, INPUT);
  pinMode(led, OUTPUT);
  lcd.clear();
  lcd.print(" Access Control ");
  lcd.setCursor(0,1);
  lcd.print("Scan Your Card:");
  // Read motion sensor and update servo
  digitalWrite(A3,LOW);
  myservo.write(10);
  switch_state = digitalRead(switcher);
  if(switch_state == HIGH)
    digitalWrite(trig2, LOW);
    delayMicroseconds(2);
    digitalWrite(trig2, HIGH);
    delayMicroseconds(10);
    duration2 = pulseIn(echo2, HIGH);
    distance2 = duration2 * 0.034 / 2;
    isObjectDetected = distance2 <= threshold;
    if (isObjectDetected) {
      servoPosition = 360;
      digitalWrite(led,HIGH);
      Serial.println(distance2);
      Serial.println("Object Detected");
      servoPosition = 0;
      digitalWrite(led,LOW);
      Serial.println("Object not Detected");
    myservo.write(servoPosition);
    delay(isObjectDetected ? 1000 : 2000); // Use ternary operator for concise delay
    while(getUID())
      Serial.print("UID: ");
      Serial.println(UIDcard);
      lcd.clear();
      lcd.setCursor(2, 0);
      lcd.print("Restricted");
      lcd.setCursor(0, 1);
      if(UIDcard == Mastertag)
        lcd.print("Access Granted");
        myservo.write(100);
        delay(50);
        for(int i = 0; i < 10;i++){
          digitalWrite(led, HIGH);
          delay(250);
          digitalWrite(led, LOW);
          delay(250);
        lcd.print("Access Denied");
        myservo.write(10);
      delay(2000);
      lcd.clear();
      lcd.setCursor(0,1);
      lcd.print("Scan Your Card>>");
  // Read ultrasonic sensor and control LED
  digitalWrite(trig1, LOW);
  digitalWrite(trig1, HIGH);
  duration = pulseIn(echo1, HIGH);
  distance = duration * 0.034 / 2;
  // LED control based on distance from sensor 1 (optional)
  if (distance < 10) {
    digitalWrite(A3,HIGH);
    Serial.println("Too Close!!!");
    Serial.println("Come Close");
boolean getUID()
  if (! rfid.PICC_IsNewCardPresent()) {
    //Serial.println("card Not found");
    return false;
  if (! rfid.PICC_ReadCardSerial()) {
    //Serial.println("Not able to read the card");
    return false;
  UIDcard = "";
  for (byte i = 0; i < rfid.uid.size; i++) {
    UIDcard.concat(String(rfid.uid.uidByte[i] < 0x10 ? " 0" : " "));
    UIDcard.concat(String(rfid.uid.uidByte[i], HEX));
  UIDcard.toUpperCase();
  UIDcard = UIDcard.substring(1);
  rfid.PICC_HaltA();
  return true;
Welcome to the forum
It is not a good idea to power a servo from the Arduino but i suspect that you have other problems so please post your test sketch, using code tags when you do
Please post a schematic of your project. A 'photo of a pencil and paper drawing is good enough
Just updated it, the code im not sure if its completely right, saw a youtube video of someone doing about the same thing and copied that code and made a few changes.
