Arduino Uno R4 Wifi
Hi guys, I encountered a problem on Arduino Uno R4 Wifi. I used the 2 interrupt pins which is the digital pin 2 and 3, and also it is connected to arduino cloud. On pin 3 a coin acceptor is connected while on pin 2 a water flow sensor is connected. The pin 3 works because the arduino reads the pulse but in pin 2 it doesnt read the pulses sent by the sensor. Did someone also experience case?
The problem could be in your sketch but you did not post it or it could be in your circuit but you did not post a schematic
Are you sure that the flow sensor is sending a pulse ?
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
