Arduino Uno Wifi
I am trying the attached sketch udp client-server (client-test.ino) as a udp-server with the udpclient.c as a client
Hardware "Arduino Uno WiFI"
From the part of the client ....
root@jb-home:~# ./udpclient 192.168.1.140 49150
Type a sentence to send to server: Hello there
You typed: Hello there
From the part of the server ....
Attempting to connect to SSID: Lithinon
Connected to wifi
FirmWare Version: 1.0.0
SSID: Lithinon
IP Address: 192.168.1.140
signal strength (RSSI):-68 dBm
Starting connection to server...
I get no reply.....any hint?
client-test.ino (2.68 KB)
udpclient.c (1.39 KB)
Print a message AFTER the call to Udp.begin(). If that never returns, loop() will never begin.
the WiFi Link versions 1.0.x are full of bugs.
I did it already, but the problem is the same.
I made bug-fixes to WiFi Link firmware and library in my forks. Use it with my Uno WiFi Serial1 library.
You changed your code, but did not post the revisions.
You should get more serial output. You did not post that new output.
The problem is the same - you are it.
Hi Juraj
I try firmware download following GitHub - JAndrassy/UnoWiFiDevEdSerial1: Implements Serial1 of Arduino Uno WiFi Developer Edition board to access the on-board ESP8266
but fail
in the attached screenshot you can find details
d
johnbotsis:
Hi Juraj
but fail
did you let the Serial Monitor open? and remove the Hello println it disturbs the esptool.
and why do you install the AT firmware?
I see, the link to GitHub jumps up on the page. Follow "UNO WiFi with WiFi Link firmware" chapter.
Hi Juraj,
I select Arduino Uno WiFi board but the compilation gives
Arduino: 1.8.5 (Windows 7), Board: "Arduino Uno WiFi"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\johnbotsis\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\johnbotsis\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\johnbotsis\Documents\Arduino\libraries -fqbn=arduino:avr:unowifi -ide-version=10805 -build-path C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867 -warnings=none -build-cache C:\Users\johnbotsis\AppData\Local\Temp\arduino_cache_302589 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\johnbotsis\Documents\Arduino\ArduinoFirmwareEsp\ArduinoFirmwareEsp.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\johnbotsis\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\johnbotsis\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\johnbotsis\Documents\Arduino\libraries -fqbn=arduino:avr:unowifi -ide-version=10805 -build-path C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867 -warnings=none -build-cache C:\Users\johnbotsis\AppData\Local\Temp\arduino_cache_302589 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\johnbotsis\Documents\Arduino\ArduinoFirmwareEsp\ArduinoFirmwareEsp.ino
Using board 'unowifi' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO_WIFI_DEV_ED -DARDUINO_ARCH_AVR -DESP_CH_UART -DESP_CH_UART_BR=19200 "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867\sketch\ArduinoFirmwareEsp.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO_WIFI_DEV_ED -DARDUINO_ARCH_AVR -DESP_CH_UART -DESP_CH_UART_BR=19200 "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867\sketch\ArduinoFirmwareEsp.ino.cpp" -o "C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867\preproc\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\johnbotsis\Documents\Arduino\ArduinoFirmwareEsp\ArduinoFirmwareEsp.ino:1:0:
C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867\sketch\CommLgc.h:25:25: fatal error: ESP8266WiFi.h: No such file or directory
#include <ESP8266WiFi.h>
compilation terminated.
exit status 1
Error compiling for board Arduino Uno WiFi.
you should select Arduino board from esp8266 core for Arduino IDE. did you install it?
Yes but now
Arduino: 1.8.5 (Windows 7), Board: "Arduino, Uno WiFi, 80 MHz, 4M (1M SPIFFS), v1.4 Compile from source, Disabled, None, Only Sketch, 115200"
Using board 'arduino-esp8266' from platform in folder: C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1
Using core 'esp8266' from platform in folder: C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1
Build options changed, rebuilding all
"C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/include" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/lwip/include" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ARDUINO_UNOWIFI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ARDUINO_UNOWIFI" -DF_CRYSTAL=40000000 -DESP8266 "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\variants\arduino_uart" "C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867\sketch\ArduinoFirmwareEsp.ino.cpp" -o "nul"
"C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/include" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/lwip/include" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ARDUINO_UNOWIFI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ARDUINO_UNOWIFI" -DF_CRYSTAL=40000000 -DESP8266 "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\variants\arduino_uart" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WiFi\src" "C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867\sketch\ArduinoFirmwareEsp.ino.cpp" -o "nul"
"C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/include" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/lwip/include" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ARDUINO_UNOWIFI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ARDUINO_UNOWIFI" -DF_CRYSTAL=40000000 -DESP8266 "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\variants\arduino_uart" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WiFi\src" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266mDNS" "C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867\sketch\ArduinoFirmwareEsp.ino.cpp" -o "nul"
"C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/include" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/lwip/include" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ARDUINO_UNOWIFI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ARDUINO_UNOWIFI" -DF_CRYSTAL=40000000 -DESP8266 "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\variants\arduino_uart" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WiFi\src" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266mDNS" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ArduinoOTA" "C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867\sketch\ArduinoFirmwareEsp.ino.cpp" -o "nul"
"C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/include" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/lwip/include" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ARDUINO_UNOWIFI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ARDUINO_UNOWIFI" -DF_CRYSTAL=40000000 -DESP8266 "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\variants\arduino_uart" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WiFi\src" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266mDNS" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ArduinoOTA" "C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867\sketch\ArduinoFirmwareEsp.ino.cpp" -o "C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867\preproc\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\johnbotsis\Documents\Arduino\ArduinoFirmwareEsp\ArduinoFirmwareEsp.ino:6:0:
C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_321867\sketch\Configuration.h:26:25: fatal error: ArduinoJson.h: No such file or directory
#include <ArduinoJson.h>
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WiFi
Using library ESP8266mDNS in folder: C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266mDNS (legacy)
Using library ArduinoOTA at version 1.0 in folder: C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ArduinoOTA
exit status 1
Error compiling for board Arduino.
install ArduinoJson library in Library Manager
a new error in PATH
C:\Users\johnbotsis\Documents\Arduino\libraries\ArduinoJson
Using library Hash at version 1.0 in folder: C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\Hash
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WebServer
Using library SPISlave at version 1.0 in folder: C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\SPISlave
exec: "make": executable file not found in %PATH%
The problem is caused by selecting Tools > lwIP Variant > v1.4 Compile from source when you don't have the path to make in your PATH environment variable (likely not installed at all since you're on Windows). The problem will be solved if you select Tools > lwIP Variant > v1.4 Higher Bandwidth.
I installed WiFi Link Library from GitHub - JAndrassy/arduino-library-wifilink: Arduino Library WiFi Link and i try
WiFi UDP Send and Receive String example but i get the following errors.
Any Hint ?
wifi link errors.txt (27.9 KB)
now select the avr board Arduino Uno WiFi.
and first try the WiFiLinkWebClient example of Uno WiFi Serial1 library
Hi juraj,
I am trying from the beginning with new installation of arduino IDE.
In the step "Arduino ESP8266 filesystem uploader"
I take that, us you can see in the attached file.....
What am I doing wrong?
johnbotsis:
did you upload EspProxy in flashing mode to Atmega?
Arduino: 1.8.5 (Windows 7), Board: "Arduino, Uno WiFi, 80 MHz, 4M (1M SPIFFS), v1.4 Higher Bandwidth, Disabled, None, Only Sketch, 115200"
"C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/include" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/lwip/include" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\johnbotsis\AppData\Local\Temp\arduino_build_692484/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ARDUINO_UNOWIFI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ARDUINO_UNOWIFI" -DF_CRYSTAL=40000000 -DESP8266 "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\variants\arduino_uart" "-IC:\Users\johnbotsis\Documents\Arduino\libraries\UnoWiFiDevEdSerial1-master\src" "-IC:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\Wire" "C:\Users\johnbotsis\Documents\Arduino\libraries\UnoWiFiDevEdSerial1-master\src\UnoWiFiDevEdSerial1.cpp" -o "C:\Users\johnbotsis\AppData\Local\Temp\arduino_build_692484\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\johnbotsis\Documents\Arduino\libraries\UnoWiFiDevEdSerial1-master\src\UnoWiFiDevEdSerial1.cpp:23:47: fatal error: utility/twi.h: No such file or directory
#include <utility/twi.h> //from Wire library
Using library UnoWiFiDevEdSerial1-master at version 1.0.2 in folder: C:\Users\johnbotsis\Documents\Arduino\libraries\UnoWiFiDevEdSerial1-master
Using library Wire at version 1.0 in folder: C:\Users\johnbotsis\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\Wire
exit status 1
You forgot to follow the directions:
Juraj:
Select Tools > Board > Arduino Uno WiFi.
