Assistance requested on SSD1305 sketch
Hi All, I have an OLED that runs on the SSD1305 library, and am successfully able to run the test sketch here GitHub - adafruit/Adafruit_SSD1305: OLEDs with SSD1305
However I'm now trying to use the sketch to just do a simple display of a line to learn how to use it for a specific task, and have written and successfully compiled the following sketch.
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1305.h>
// Used for software SPI
#define OLED_CLK 13
#define OLED_MOSI 11
// Used for software or hardware SPI
#define OLED_CS 10
#define OLED_DC 12
// Used for I2C or SPI
#define OLED_RESET 9
// software SPI
//Adafruit_SSD1305 display(128, 32, OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
// hardware SPI - use 7Mhz (7000000UL) or lower because the screen is rated for 4MHz, or it will remain blank!
Adafruit_SSD1305 display(128, 32, &SPI, OLED_DC, OLED_RESET, OLED_CS, 6000000UL);
// I2C
//Adafruit_SSD1305 display(128, 64, &Wire, OLED_RESET);
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(40, 20);
  display.println("test");
  display.display();
The sketch does not display the requested text, can someone advise on the correct syntax for the simple display?
Thanks
Les
Did you test the display by running one of the example sketches so you know you have connected it right?
If not, do that now. Either way, take a look at that example sketch and see what library functions it uses, especially in setup(). Does your code use those functions?
Thanks, I have successfully run the test sketch, and was using it (it's the only example sketch I can find for this SSD1305 type) to try and reverse engineer the simple sketch. The problem is I cannot find the list of applicable functions for this Library in the same way I found for the U8G2 and other ones
The wiring is fine, so clearly my understanding of this library is the problem!
Les
display.begin() may be needed, most likely.
Yes, this is in the (reportedly working) test sketch.
  if ( ! display.begin(0x3C) ) {
     Serial.println("Unable to initialize OLED");
     while (1) yield();
I hoped that with my suggestion, @Lesthegringo would be able to spot what was missing by himself. It's a good way to learn. Oh well.
So I actually was considering the display.begin part but I clearly misinterpreted its use in this case, as it only seemed to be part of an 'if' function. As such it was one of those situations where the use made me think it was not the issue
So I have updated the sketch with this,
#include <Wire.h>
#include <SPI.h>
#define OLED_CLK 13
#define OLED_CS 10
#define OLED_DC 12
// software SPI
// I2C
  display.begin(0x3C);
  display.clearDisplay();
  display.display();
and the display now 'works' but does not display the 'test' text, but instead seems to be stuck displaying the stars from teh example sketch - even with the clearDisplay command - should that happen?
Les
That's not code, Les, please don't put it in code tags! :wink:
No, it shouldn't happen. You you mean the small animated falling/raining stars? Are you sure you uploaded your code successfully, overwriting the example sketch ?
I know that Adafruit OLED libraries do display the Adafruit logo when .begin() is called, but I didn't think they displayed those animated stars. You only see the logo if you call .display() before .clearDisplay().
The "if" tests whether the .begin method worked, and informs you if it doesn't.
If you don't think that "failure to begin" would be useful information, then by all means leave out that test.
Hi @Lesthegringo,
I suggest you follow @anon94801460 's suggestion and use the full code from post #5.
It would be very helpful for further assistance to know whether the error message is printed or not ...
I included the full test code
  while (! Serial) delay(100);
  Serial.println("SSD1305 OLED test");
     while (1) yield();
The serial monitor reports SSD1305 OLED test therefore clearly that bit at least is functioning.
However it still displays the stars or snowflakes or whatever they are but static. As there is no mention of it in the sketch, all I can assume is that the older sketch has not been fully overwriten or purged by the new one?
Les
Thanks! If you want to be quite sure you could add a Serial.println("Initialized"); or the like after the test functions....
Next test could be to upload the example sketch once more. If it works please post that sketch here for comparison reasons. Maybe someone sees a significant difference...
Maybe too simple but did you try a
Display.display();
before the first clearDisplay() as in the example
// init done
  display.display(); // show splashscreen
  display.clearDisplay();   // clears the screen and buffer
Just re-uploaded it, works fine, this is the full example sketch
This is a library for our Monochrome OLEDs based on SSD1305 drivers
  Pick one up today in the adafruit shop!
  ------> https://www.adafruit.com/products/2675
These displays use SPI or I2C to communicate, 3-5 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada  for Adafruit Industries.
BSD license, check license.txt for more information
All text above, and the splash screen below must be included in any redistribution
#include <Wire.h>
#include <SPI.h>
#define OLED_CLK 13
#define OLED_CS 10
#define OLED_DC 8
// software SPI
//Adafruit_SSD1305 display(128, 32, &SPI, OLED_DC, OLED_RESET, OLED_CS, 6000000UL);
// I2C
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
static const unsigned char PROGMEM logo16_glcd_bmp[] =
{ B00000000, B11000000,
  B00000001, B11000000,
  B00000011, B11100000,
  B11110011, B11100000,
  B11111110, B11111000,
  B01111110, B11111111,
  B00110011, B10011111,
  B00011111, B11111100,
  B00001101, B01110000,
  B00011011, B10100000,
  B00111111, B11100000,
  B00111111, B11110000,
  B01111100, B11110000,
  B01110000, B01110000,
  B00000000, B00110000 };
void setup()   {
     while (1) yield();
  // init done
  // draw a single pixel
  display.drawPixel(10, 10, WHITE);
  display.display();
  // draw many lines
  testdrawline();
  display.display();
  // draw rectangles
  testdrawrect();
  display.display();
  // draw multiple rectangles
  testfillrect();
  display.display();
  // draw mulitple circles
  testdrawcircle();
  display.display();
  // draw a white circle, 10 pixel radius
  display.fillCircle(display.width()/2, display.height()/2, 10, WHITE);
  display.display();
  testdrawroundrect();
  testfillroundrect();
  testdrawtriangle();
  testfilltriangle();
  // draw the first ~12 characters in the font
  testdrawchar();
  display.display();
  for (uint8_t rot=0; rot < 4; rot++) {
    display.setRotation(rot);
    // text display tests
    display.setCursor(0,0);
    display.println("Hello, world!");
    display.setTextColor(BLACK, WHITE); // 'inverted' text
    display.println(3.141592);
    display.setTextSize(2);
    display.print("0x"); display.println(0xDEADBEEF, HEX);
    display.display();
  display.setRotation(0);
  // miniature bitmap display
  display.drawBitmap(30, 16,  logo16_glcd_bmp, 16, 16, 1);
  display.display();
  // invert the display
  display.invertDisplay(true);
  display.invertDisplay(false);
  // draw a bitmap icon and 'animate' movement
  testdrawbitmap(logo16_glcd_bmp, LOGO16_GLCD_HEIGHT, LOGO16_GLCD_WIDTH);
void testdrawbitmap(const uint8_t *bitmap, uint8_t w, uint8_t h) {
  uint8_t icons[NUMFLAKES][3];
  randomSeed(666);     // whatever seed
  // initialize
  for (uint8_t f=0; f< NUMFLAKES; f++) {
    icons[f][XPOS] = random(display.width());
    icons[f][YPOS] = 0;
    icons[f][DELTAY] = random(5) + 1;
    Serial.print("x: ");
    Serial.print(icons[f][XPOS], DEC);
    Serial.print(" y: ");
    Serial.print(icons[f][YPOS], DEC);
    Serial.print(" dy: ");
    Serial.println(icons[f][DELTAY], DEC);
  while (1) {
    // draw each icon
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS], logo16_glcd_bmp, w, h, WHITE);
    display.display();
    delay(200);
    // then erase it + move it
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS],  logo16_glcd_bmp, w, h, BLACK);
      // move it
      icons[f][YPOS] += icons[f][DELTAY];
      // if its gone, reinit
      if (icons[f][YPOS] > display.height()) {
	icons[f][YPOS] = 0;
void testdrawchar(void) {
  display.setTextWrap(false);
  for (uint8_t i=0; i < 168; i++) {
    if (i == '\n') continue;
    display.write(i);
    if ((i > 0) && (i % 21 == 0))
      display.println();
  display.display();
void testdrawcircle(void) {
  for (uint8_t i=0; i<display.height(); i+=2) {
    display.drawCircle(display.width()/2, display.height()/2, i, WHITE);
    display.display();
void testfillrect(void) {
  uint8_t color = 1;
  for (uint8_t i=0; i<display.height()/2; i+=3) {
    // alternate colors
    display.fillRect(i, i, display.width()-i*2, display.height()-i*2, color%2);
    display.display();
    color++;
void testdrawtriangle(void) {
  for (uint16_t i=0; i<min(display.width(),display.height())/2; i+=5) {
    display.drawTriangle(display.width()/2, display.height()/2-i,
                     display.width()/2-i, display.height()/2+i,
                     display.width()/2+i, display.height()/2+i, WHITE);
    display.display();
void testfilltriangle(void) {
  uint8_t color = WHITE;
  for (int16_t i=min(display.width(),display.height())/2; i>0; i-=5) {
    display.fillTriangle(display.width()/2, display.height()/2-i,
    if (color == WHITE) color = BLACK;
    else color = WHITE;
    display.display();
void testdrawroundrect(void) {
  for (uint8_t i=0; i<display.height()/3-2; i+=2) {
    display.drawRoundRect(i, i, display.width()-2*i, display.height()-2*i, display.height()/4, WHITE);
    display.display();
void testfillroundrect(void) {
    display.fillRoundRect(i, i, display.width()-2*i, display.height()-2*i, display.height()/4, color);
    else color = WHITE;
    display.display();
void testdrawrect(void) {
  for (uint8_t i=0; i<display.height()/2; i+=2) {
    display.drawRect(i, i, display.width()-2*i, display.height()-2*i, WHITE);
    display.display();
void testdrawline() {
  for (uint8_t i=0; i<display.width(); i+=4) {
    display.drawLine(0, 0, i, display.height()-1, WHITE);
    display.display();
  for (uint8_t i=0; i<display.height(); i+=4) {
    display.drawLine(0, 0, display.width()-1, i, WHITE);
    display.display();
  delay(250);
    display.drawLine(0, display.height()-1, i, 0, WHITE);
    display.display();
  for (int8_t i=display.height()-1; i>=0; i-=4) {
    display.drawLine(0, display.height()-1, display.width()-1, i, WHITE);
    display.display();
  delay(250);
  for (int8_t i=display.width()-1; i>=0; i-=4) {
    display.drawLine(display.width()-1, display.height()-1, i, 0, WHITE);
    display.display();
    display.drawLine(display.width()-1, display.height()-1, 0, i, WHITE);
    display.display();
  delay(250);
    display.drawLine(display.width()-1, 0, 0, i, WHITE);
    display.display();
    display.drawLine(display.width()-1, 0, i, display.height()-1, WHITE);
    display.display();
  delay(250);
I tried uploading the simple test sketch, this one
#include <Wire.h>
#include <SPI.h>
#define OLED_CLK 13
#define OLED_CS 10
#define OLED_DC 12
// software SPI
// I2C
     while (1) yield();
  display.display();
It's the same result, the stars / snowflakes are still there
Cheers
Les
Please see the added part in my post above ...
Posts crossed in the ether, let me check
Les
Just tried the sketch below, still got the stars / snowflakes
#include <Wire.h>
#include <SPI.h>
#define OLED_CLK 13
#define OLED_CS 10
#define OLED_DC 12
// software SPI
// I2C
     while (1) yield();
  display.display();
Cheers
Les
Have you done a power cycle? That should eliminate anything left over in the display buffer.
Start with the library test code, and take out everything but the display initialization, and the part that prints some text. Let us know if that works to display text.
This sketch shows the AdaFruit logo, then prints Hello World plus some text letters
interface
#include <Wire.h>
#include <SPI.h>
#define OLED_CLK 13
#define OLED_CS 10
#define OLED_DC 8
// software SPI
// I2C
void setup()   {
     while (1) yield();
  // init done
    display.display();
    display.write(i);
      display.println();
  display.display();
    display.display();
  uint8_t color = 1;
    // alternate colors
    display.display();
    color++;
    display.display();
    else color = WHITE;
    display.display();
    display.display();
    else color = WHITE;
    display.display();
    display.display();
    display.display();
    display.display();
  delay(250);
    display.display();
    display.display();
  delay(250);
    display.display();
    display.display();
  delay(250);
    display.display();
    display.display();
  delay(250);
If I then load up my simple test sketch, it shows a moment of static, then goes back to the Hello World and the text letters
Cheers
You Initialize twice now ... please delete the two unnecessary lines:
I guess that the second call of begin() just reloads the logo.
Since the pared-down example prints text, it would be a fine place to start, and get on with your project.
Why did you change the pin number here, when the example works with pin 8?
#define OLED_DC 12
