Ship style radar display
I'm trying to come up with a way to display a ship style radar display, I want to display it on a mini oled screen in an RC Lifeboat
thanks for this, i'm having trouble with height error code any ideas
It is looking for height of 64.
#if (SSD1306_LCDHEIGHT != 64)
The code says to adjust the library file...
so I've been sent this file by someone (GitHub - labomat/Radar-Simulator: Simulated vintage radar screen for model boats), but when i try to verify the file it comes up with the following error
exit status 1
Compilation error: #error ("Height incorrect, please fix Adafruit_SSD1306.h!");
i did google a fix for this but its saying correct something in line 72-75 but the example they give is different to my version, my version seems to have more text and code in those lines
Please post the sketch here, using code tags when you do
I'm a complete noob here, I'm surprised I managed to get it into the ide program :pensive::grinning: give me a clue
Does this discussion help:
Hi, @Paulcobra
To add code please click this link;
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Right there.
is it just that line i need to change or the following ones too
That's the line you don't want.
It would be easier to read if you'd used code tags.
Which display do you have?
2:1 aspect is a bit odd for a radar display, no?
i have a few different ones, not sure yet which size will look best in my RC Lifeboat,
0.96" tft 2 of
0.9 x 1.3" OLED
1.77" tft
 * @file Adafruit_SSD1306.h
 * This is part of for Adafruit's SSD1306 library for monochrome
 * OLED displays: http://www.adafruit.com/category/63_98
 * These displays use I2C or SPI to communicate. I2C requires 2 pins
 * (SCL+SDA) and optionally a RESET pin. SPI requires 4 pins (MOSI, SCK,
 * select, data/command) and optionally a reset pin. Hardware SPI or
 * 'bitbang' software SPI are both supported.
 * Adafruit invests time and resources providing this open source code,
 * please support Adafruit and open-source hardware by purchasing
 * products from Adafruit!
 * Written by Limor Fried/Ladyada for Adafruit Industries, with
 * contributions from the open source community.
 * BSD license, all text above, and the splash screen header file,
 * must be included in any redistribution.
#ifndef _Adafruit_SSD1306_H_
#define _Adafruit_SSD1306_H_
// ONE of the following three lines must be #defined:
//#define SSD1306_128_64 ///< DEPRECTAED: old way to specify 128x64 screen
//#define SSD1306_96_16  ///< DEPRECATED: old way to specify 96x16 screen
// This establishes the screen dimensions in old Adafruit_SSD1306 sketches
// (NEW CODE SHOULD IGNORE THIS, USE THE CONSTRUCTORS THAT ACCEPT WIDTH
// AND HEIGHT ARGUMENTS).
// Uncomment to disable Adafruit splash logo
//#define SSD1306_NO_SPLASH
#if defined(ARDUINO_STM32_FEATHER)
typedef class HardwareSPI SPIClass;
#endif
#include <Adafruit_GFX.h>
#include <SPI.h>
#include <Wire.h>
#if defined(__AVR__)
typedef volatile uint8_t PortReg;
typedef uint8_t PortMask;
#define HAVE_PORTREG
#elif defined(__SAM3X8E__)
typedef volatile RwReg PortReg;
typedef uint32_t PortMask;
#elif (defined(__arm__) || defined(ARDUINO_FEATHER52)) &&                      \
    !defined(ARDUINO_ARCH_MBED) && !defined(ARDUINO_ARCH_RP2040)
typedef volatile uint32_t PortReg;
#endif
/// The following "raw" color names are kept for backwards client compatability
/// They can be disabled by predefining this macro before including the Adafruit
/// header client code will then need to be modified to use the scoped enum
/// values directly
#ifndef NO_ADAFRUIT_SSD1306_COLOR_COMPATIBILITY
#define BLACK SSD1306_BLACK     ///< Draw 'off' pixels
#define WHITE SSD1306_WHITE     ///< Draw 'on' pixels
#define INVERSE SSD1306_INVERSE ///< Invert pixels
#endif
/// fit into the SSD1306_ naming scheme
#define SSD1306_BLACK 0   ///< Draw 'off' pixels
#define SSD1306_WHITE 1   ///< Draw 'on' pixels
#define SSD1306_INVERSE 2 ///< Invert pixels
#define SSD1306_MEMORYMODE 0x20          ///< See datasheet
#define SSD1306_COLUMNADDR 0x21          ///< See datasheet
#define SSD1306_PAGEADDR 0x22            ///< See datasheet
#define SSD1306_SETCONTRAST 0x81         ///< See datasheet
#define SSD1306_CHARGEPUMP 0x8D          ///< See datasheet
#define SSD1306_SEGREMAP 0xA0            ///< See datasheet
#define SSD1306_DISPLAYALLON_RESUME 0xA4 ///< See datasheet
#define SSD1306_DISPLAYALLON 0xA5        ///< Not currently used
#define SSD1306_NORMALDISPLAY 0xA6       ///< See datasheet
#define SSD1306_INVERTDISPLAY 0xA7       ///< See datasheet
#define SSD1306_SETMULTIPLEX 0xA8        ///< See datasheet
#define SSD1306_DISPLAYOFF 0xAE          ///< See datasheet
#define SSD1306_DISPLAYON 0xAF           ///< See datasheet
#define SSD1306_COMSCANINC 0xC0          ///< Not currently used
#define SSD1306_COMSCANDEC 0xC8          ///< See datasheet
#define SSD1306_SETDISPLAYOFFSET 0xD3    ///< See datasheet
#define SSD1306_SETDISPLAYCLOCKDIV 0xD5  ///< See datasheet
#define SSD1306_SETPRECHARGE 0xD9        ///< See datasheet
#define SSD1306_SETCOMPINS 0xDA          ///< See datasheet
#define SSD1306_SETVCOMDETECT 0xDB       ///< See datasheet
#define SSD1306_SETLOWCOLUMN 0x00  ///< Not currently used
#define SSD1306_SETHIGHCOLUMN 0x10 ///< Not currently used
#define SSD1306_SETSTARTLINE 0x40  ///< See datasheet
#define SSD1306_EXTERNALVCC 0x01  ///< External display voltage source
#define SSD1306_SWITCHCAPVCC 0x02 ///< Gen. display voltage from 3.3V
#define SSD1306_RIGHT_HORIZONTAL_SCROLL 0x26              ///< Init rt scroll
#define SSD1306_LEFT_HORIZONTAL_SCROLL 0x27               ///< Init left scroll
#define SSD1306_VERTICAL_AND_RIGHT_HORIZONTAL_SCROLL 0x29 ///< Init diag scroll
#define SSD1306_VERTICAL_AND_LEFT_HORIZONTAL_SCROLL 0x2A  ///< Init diag scroll
#define SSD1306_DEACTIVATE_SCROLL 0x2E                    ///< Stop scroll
#define SSD1306_ACTIVATE_SCROLL 0x2F                      ///< Start scroll
#define SSD1306_SET_VERTICAL_SCROLL_AREA 0xA3             ///< Set scroll range
// Deprecated size stuff for backwards compatibility with old sketches
#if defined SSD1306_128_64
#define SSD1306_LCDWIDTH 128 ///< DEPRECATED: width w/SSD1306_128_64 defined
#define SSD1306_LCDHEIGHT 64 ///< DEPRECATED: height w/SSD1306_128_64 defined
#endif
#if defined SSD1306_128_32
#define SSD1306_LCDWIDTH 128 ///< DEPRECATED: width w/SSD1306_128_32 defined
#define SSD1306_LCDHEIGHT 32 ///< DEPRECATED: height w/SSD1306_128_32 defined
#endif
#if defined SSD1306_96_16
#define SSD1306_LCDWIDTH 96  ///< DEPRECATED: width w/SSD1306_96_16 defined
#define SSD1306_LCDHEIGHT 16 ///< DEPRECATED: height w/SSD1306_96_16 defined
#endif
    @brief  Class that stores state and functions for interacting with
            SSD1306 OLED displays.
class Adafruit_SSD1306 : public Adafruit_GFX {
public:
  // NEW CONSTRUCTORS -- recommended for new projects
  Adafruit_SSD1306(uint8_t w, uint8_t h, TwoWire *twi = &Wire,
                   int8_t rst_pin = -1, uint32_t clkDuring = 400000UL,
                   uint32_t clkAfter = 100000UL);
  Adafruit_SSD1306(uint8_t w, uint8_t h, int8_t mosi_pin, int8_t sclk_pin,
                   int8_t dc_pin, int8_t rst_pin, int8_t cs_pin);
  Adafruit_SSD1306(uint8_t w, uint8_t h, SPIClass *spi, int8_t dc_pin,
                   int8_t rst_pin, int8_t cs_pin, uint32_t bitrate = 8000000UL);
  // DEPRECATED CONSTRUCTORS - for back compatibility, avoid in new projects
  Adafruit_SSD1306(int8_t mosi_pin, int8_t sclk_pin, int8_t dc_pin,
  Adafruit_SSD1306(int8_t dc_pin, int8_t rst_pin, int8_t cs_pin);
  Adafruit_SSD1306(int8_t rst_pin = -1);
  ~Adafruit_SSD1306(void);
  bool begin(uint8_t switchvcc = SSD1306_SWITCHCAPVCC, uint8_t i2caddr = 0,
             bool reset = true, bool periphBegin = true);
  void display(void);
  void clearDisplay(void);
  void invertDisplay(bool i);
  void dim(bool dim);
  void drawPixel(int16_t x, int16_t y, uint16_t color);
  virtual void drawFastHLine(int16_t x, int16_t y, int16_t w, uint16_t color);
  virtual void drawFastVLine(int16_t x, int16_t y, int16_t h, uint16_t color);
  void startscrollright(uint8_t start, uint8_t stop);
  void startscrollleft(uint8_t start, uint8_t stop);
  void startscrolldiagright(uint8_t start, uint8_t stop);
  void startscrolldiagleft(uint8_t start, uint8_t stop);
  void stopscroll(void);
  void ssd1306_command(uint8_t c);
  bool getPixel(int16_t x, int16_t y);
  uint8_t *getBuffer(void);
protected:
  inline void SPIwrite(uint8_t d) __attribute__((always_inline));
  void drawFastHLineInternal(int16_t x, int16_t y, int16_t w, uint16_t color);
  void drawFastVLineInternal(int16_t x, int16_t y, int16_t h, uint16_t color);
  void ssd1306_command1(uint8_t c);
  void ssd1306_commandList(const uint8_t *c, uint8_t n);
  SPIClass *spi;   ///< Initialized during construction when using SPI. See
                   ///< SPI.cpp, SPI.h
  TwoWire *wire;   ///< Initialized during construction when using I2C. See
                   ///< Wire.cpp, Wire.h
  uint8_t *buffer; ///< Buffer data used for display buffer. Allocated when
                   ///< begin method is called.
  int8_t i2caddr;  ///< I2C address initialized when begin method is called.
  int8_t vccstate; ///< VCC selection, set by begin method.
  int8_t page_end; ///< not used
  int8_t mosiPin;  ///< (Master Out Slave In) set when using SPI set during
                   ///< construction.
  int8_t clkPin;   ///< (Clock Pin) set when using SPI set during construction.
  int8_t dcPin;    ///< (Data Pin) set when using SPI set during construction.
  int8_t
      csPin; ///< (Chip Select Pin) set when using SPI set during construction.
  int8_t rstPin; ///< Display reset pin assignment. Set during construction.
#ifdef HAVE_PORTREG
  PortReg *mosiPort, *clkPort, *dcPort, *csPort;
  PortMask mosiPinMask, clkPinMask, dcPinMask, csPinMask;
#endif
#if ARDUINO >= 157
  uint32_t wireClk;    ///< Wire speed for SSD1306 transfers
  uint32_t restoreClk; ///< Wire speed following SSD1306 transfers
#endif
  uint8_t contrast; ///< normal contrast setting for this device
#if defined(SPI_HAS_TRANSACTION)
protected:
  // Allow sub-class to change
  SPISettings spiSettings;
#endif
#endif // _Adafruit_SSD1306_H_
Isn't it a question of which one the code is written for?
scale wise i'm hoping to use either the 0.9" square or the 0.9 x 1.3"
I posted the question of if it were possible to do and I was sent this program via PM
@Paulcobra
Your newly opened duplicate topic has been closed
Why did you start a second topic on the same subject ?
Because I'm stupid and don't know what I'm doing and people are obviously getting annoyed that I haven't inputted my question and code like an expert
They would have been even more annoyed had I let the other topic stand
