Hey, guys,
Now I'm working on a motor speed regulation project. I saw a program based on atmega328p Au processor. There's no problem with Arduino compilation, but now I want to use esp32 development board to replace atmega328p Au. There are errors in the compilation of timer. Please tell me how to modify it?
source program ↓
String mySt = "";
char myChar;
boolean stringComplete = false; // whether the string is complete
boolean motor_start = false;
const byte pin_a = 2; //for encoder pulse A
const byte pin_b = 3; //for encoder pulse B
const byte pin_fwd = 4; //for H-bridge: run motor forward
const byte pin_bwd = 5; //for H-bridge: run motor backward
const byte pin_pwm = 6; //for H-bridge: motor speed
int encoder = 0;
int m_direction = 0;
int sv_speed = 100; //this value is 0~255
double pv_speed = 0;
double set_speed = 0;
double e_speed = 0; //error of speed = set_speed - pv_speed
double e_speed_pre = 0; //last error of speed
double e_speed_sum = 0; //sum error of speed
double pwm_pulse = 0; //this value is 0~255
double kp = 0;
double ki = 0;
double kd = 0;
int timer1_counter; //for timer
int i = 0;
pinMode(pin_a, INPUT_PULLUP);
pinMode(pin_b, INPUT_PULLUP);
pinMode(pin_fwd, OUTPUT);
pinMode(pin_bwd, OUTPUT);
pinMode(pin_pwm, OUTPUT);
attachInterrupt(digitalPinToInterrupt(pin_a), detect_a, RISING);
// start serial port at 9600 bps:
//--------------------------timer setup
noInterrupts(); // disable all interrupts
TCCR1A = 0;
TCCR1B = 0;
timer1_counter = 59286; // preload timer 65536-16MHz/256/2Hz (34286 for 0.5sec) (59286 for 0.1sec)
TCNT1 = timer1_counter; // preload timer
TCCR1B |= (1 << CS12); // 256 prescaler
TIMSK1 |= (1 << TOIE1); // enable timer overflow interrupt
interrupts(); // enable all interrupts
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
analogWrite(pin_pwm, 0); //stop motor
digitalWrite(pin_fwd, 0); //stop motor
digitalWrite(pin_bwd, 0); //stop motor
if (stringComplete) {
// clear the string when COM receiving is completed
mySt = ""; //note: in code below, mySt will not become blank, mySt is blank until '\n' is received
//receive command from Visual Studio
if (mySt.substring(0, 8) == "vs_start") {
digitalWrite(pin_fwd, 1); //run motor run forward
motor_start = true;
if (mySt.substring(0, 7) == "vs_stop") {
if (mySt.substring(0, 12) == "vs_set_speed") {
set_speed = mySt.substring(12, mySt.length()).toFloat(); //get string after set_speed
if (mySt.substring(0, 5) == "vs_kp") {
kp = mySt.substring(5, mySt.length()).toFloat(); //get string after vs_kp
if (mySt.substring(0, 5) == "vs_ki") {
ki = mySt.substring(5, mySt.length()).toFloat(); //get string after vs_ki
if (mySt.substring(0, 5) == "vs_kd") {
kd = mySt.substring(5, mySt.length()).toFloat(); //get string after vs_kd
void detect_a() {
encoder += 1; //increasing encoder at new pulse
m_direction = digitalRead(pin_b); //read direction of motor
ISR(TIMER1_OVF_vect) // interrupt service routine - tick every 0.1sec
TCNT1 = timer1_counter; // set timer
pv_speed = 600.0 * (encoder / 130.0) / 0.1; //calculate motor speed, unit is rpm
encoder = 0;
//print out speed
if (Serial.available() <= 0)
Serial.println(pv_speed); //Print speed (rpm) value to Visual Studio
//PID program
if (motor_start) {
e_speed = set_speed - pv_speed;
pwm_pulse = e_speed * kp + e_speed_sum * ki + (e_speed - e_speed_pre) * kd;
e_speed_pre = e_speed; //save last (previous) error
e_speed_sum += e_speed; //sum of error
if (e_speed_sum > 1320) e_speed_sum = 1320;
if (e_speed_sum < -1320) e_speed_sum = -1320;
else {
e_speed = 0;
e_speed_pre = 0;
e_speed_sum = 0;
pwm_pulse = 0;
//update new speed
if (pwm_pulse <255 & pwm_pulse >0) {
analogWrite(pin_pwm, pwm_pulse); //set motor speed
else {
if (pwm_pulse > 255) {
analogWrite(pin_pwm, 255);
else {
void serialEvent() {
while (Serial.available()) {
// get the new byte:
char inChar = (char)Serial.read();
// add it to the inputString:
if (inChar != '\n') {
mySt += inChar;
if (inChar == '\n') {
stringComplete = true;
