Attiny 2313 and 4313
Hello, I have been checking all the posts, old ones, and i cannot find anything that helps me out.
I've been trying to burn the bootloader on attiny 2313 and 4313 and I have succeed in some of them, but most of them i have failed.
I have tried with an external clock as well, this is the output log.
if somebody can help me i would appreciate it.
vrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM19
Using Programmer : arduino
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATtiny2313
Chip Erase delay : 9000 us
PAGEL : PD4
BS2 : PD6
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 6 4 0 no 128 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 2048 32 64 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82] [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98] [20]
avrdude: Recv: . [00]
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
avrdude: Send: A [41] . [84] [20]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Send: B [42] # [23] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] [20] . [00] . [80] . [00] . [00] . [08] . [00] [20]
avrdude: Send: E [45] . [05] . [04] . [d4] . [d6] . [01] [20]
avrdude: Send: P [50] [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75] [20]
avrdude: Recv: . [14] . [00] . [00] . [00] . [10]
################################################## | 100% 0.00s
avrdude: Device signature = 0x000000 (retrying)
################################################## | 100% -0.00s
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude: Send: Q [51] [20]
avrdude done. Thank you.
Error while burning bootloader.
and i just ran it again and there is a little difference at the end
on the third try there are some numbers that changed after recv...
avrdude: Recv: . [14] . [80] [20] . [00] . [10]
avrdude: Device signature = 0x802000
avrdude: Expected signature for ATtiny2313 is 1E 91 0A
Double check chip, or use -F to override this check.
What bootloader are you trying to burn? The bootloader has be be written/compiled for your specific MCU and loading the wrong bootloader will not work.
Did you first set the fuses as required by the bootloader and supply an external oscillator if needed?
Riva:
i've tried to burn the bootloader at 1mhz and 8mhz, i've tried with and without an external oscillator
as for setting the fuses, i thought that was done when burning the bootloader
I don't know of a bootloader for the 2313 and 4313 - you program them via ISP normally (those chips have so little flash that the overhead of a bootloader would be really painful).
However, you must still do "burn bootloader" even for parts that don't have a bootloader to set the fuses correctly.
The error you are getting indicates that either the part is wired to the ISP programmer incorrectly, or you did "burn bootloader" with a clock source selected that used a crystal, and do not have a crystal connected, which makes the chip inoperable until you provide a crystal or clock source.
If ever [code] tags were needed ...
