When I went to burn the bootloader, I got whis error:
Arduino: 1.8.5 (Windows 8.1), Board: "ATtiny25/45/85, ATtiny85, Internal 8 MHz"
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -v -v -v -pattiny85 -cstk500v1 -PCOM3 -b19200 -e -Uefuse:w:0xff:m -Uhfuse:w:0xdf:m -Ulfuse:w:0xe2:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM3
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
avrdude done. Thank you.
Error while burning bootloader.
I made sure the wiring is correct. The ISP is downloading fine too.
500 error code usually means wiring issue or wrong pin. Did you verify you have the right pin? That the ATTiny85 is not backward? I'd try adding a 10k resistor between tiny's reset pin and 5v in case it's floating funny.
Using Port : COM3
I was wondering if it could be my Arduino - I have an Arduino 101. Would that change anything? (I have the board downloaded)
Are you following the link which lead you to select board as UNO ? I think your board selection of UNO may not work, since you are using Arduino 101, it shall be Intel Curie core or Arduino 101 core.
I wonder if there's some non-obvious reason the 101 doesn't work. I recall someone else complaining that they couldn't get it to work either. The 101 is a weird board, and hasn't gone over well in the market (I suspect intel paid to get their uninspiring IoT chip into an Arduino product, in the hopes of drumming up some interest in it) - and as far as I can tell, it has been a flop in the market; I hear almost no talk about it, seems very few people are using it.
People are divided about whether USBTinyISP clones or USBAsp clones work better. My core is tested with USBAsp clones (the $3-5 ones from ebay et. al.)
Tis sparkfun programmer is using Davis Mellis ATiny core. I suggest you use UNO and use DrAzzy core. At least any issue DrAzzy can help you on any issue you encounter.
