Hello,
I've successfully worked with ATTiny85s and Arduino before, but am having trouble getting started again.
Wiring:
Arduino Uno -- ATTiny85
Pin 13 -- Pin 7
Pin 12 -- Pin 6
Pin 11 -- Pin 5
Pin 10 -- Pin 1
5v -- Pin 8
GND -- Pin 4
Steps taken so far:
Uploaded the ArduinoISP example to the uno
Installed ATTinyCore by Spencer Konde from the Boards Manager
Image attached of my settings.
I've searched around and found others having this problem, but haven't been able to find the solution. Apologies if this is a repost.
Thanks in advance.
Error:
Arduino: 1.8.7 (Mac OS X), TD: 1.44, Board: "ATtiny25/45/85, Disabled, CPU, ATtiny85, 8 MHz (internal), EEPROM retained, B.O.D. Disabled, Enabled"
/Users/User/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/User/Library/Arduino15/packages/ATTinyCore/hardware/avr/1.3.3/avrdude.conf -v -pattiny85 -carduino -P/dev/cu.usbmodem1441 -b19200 -e -Uefuse:w:0xFF:m -Uhfuse:w:0b11010111:m -Ulfuse:w:0xE2:m -Uflash:w:/Users/User/Library/Arduino15/packages/ATTinyCore/hardware/avr/1.3.3/bootloaders/empty/empty_all.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/User/Library/Arduino15/packages/ATTinyCore/hardware/avr/1.3.3/avrdude.conf"
User configuration file is "/Users/User/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1441
Using Programmer : arduino
Overriding Baud Rate : 19200
Setting bit clk period : 5.0
AVR Part : ATtiny85
Chip Erase delay : 400000 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 12 4 0 no 512 4 0 4000 4500 0xff 0xff
flash 65 12 32 0 yes 8192 64 128 30000 30000 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 233116987
Firmware Version: -505556928.32766
Topcard : STK502
Vtarget : 1.8 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done. Thank you.
Error while burning bootloader.
