Hello i am trying to use attiny4313 and HC05 with uln2003 + 28byj-48, the problems I encoutered are that I cant get the attiny4313 to communicate through hc05 with bt terminal. It also doesnt read the value of the state pin of hc05, so idk what is the problem.
#include <SoftwareSerial.h>
// Vystupy pro ULN2003 (motorek)
#define IN1 PD2
#define IN2 PD3
#define IN3 PD4
#define IN4 PD5
#define ledV PB4 // LED pracuje
#define ledP PB3 // LED pro stav BT
#define staP PD6 // Vstup pro čtení stavu
SoftwareSerial BTSerial(PD0, PD1); // RX (2) | TX (3) pro HC-05
char command[16]; // Buffr pro příjem příkazu (zkráceno)
const int step_sequence[8][4] = {
{1, 0, 0, 0},
{1, 1, 0, 0},
{0, 1, 0, 0},
{0, 1, 1, 0},
{0, 0, 1, 0},
{0, 0, 1, 1},
{0, 0, 0, 1},
{1, 0, 0, 1}
void stepMotor(int step) {
digitalWrite(IN1, step_sequence[step][0]);
digitalWrite(IN2, step_sequence[step][1]);
digitalWrite(IN3, step_sequence[step][2]);
digitalWrite(IN4, step_sequence[step][3]);
void fullRotation() {
const int steps_per_rev = 4096;
for (int i = 0; i < steps_per_rev; i++) {
stepMotor(i % 8);
delayMicroseconds(1500);
void halfRotation() {
const int steps_per_half = 2048;
for (int i = 0; i < steps_per_half; i++) {
stepMotor(i % 8);
BTSerial.begin(9600); // HC-05 je standardně na 9600 baud
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(ledP, OUTPUT);
pinMode(staP, INPUT);
pinMode(ledV, OUTPUT);
if (digitalRead(staP) == 1) {
digitalWrite(ledP, HIGH);
digitalWrite(ledP, LOW);
if (BTSerial.available()) {
BTSerial.readBytesUntil('\n', command, sizeof(command)); // Čtení příkazu z Bluetooth
if (command[0] == 'c' && command[1] == 'k' && command[2] == 'j') {
int delayTime = atoi(&command[4]); // Přečte číslo po prefixu "ckj_"
BTSerial.println("čekám");
digitalWrite(ledV, HIGH);
if (delayTime > 0) {
delay(delayTime);
fullRotation();
BTSerial.println("Hotovo, dočkal jsem");
digitalWrite(ledV, LOW);
} else if (command[0] == 'b' && command[1] == 'u' && command[2] == 'l' && command[3] == 'b') {
BTSerial.println("pootáčím");
delay(2000);
halfRotation(); // nebo halfRotation, podle potřeby
BTSerial.println("pootočeno");
