I received an email from Mouser stating that Microchip has changed the End of Life for the ATTiny84A-PU to not recommended for new designs.
Is there a substitute for this? Something that fits between the ATTiny85 and ATMega328, and can be programmed using Arduino as ISP? I use an Uno to program the 84.
And you mean it needs to be DIP form factor? No SMD?
The new generation Attiny is SMD only, so I would not be surprised if all DIP packages will be end of life at some point. Maybe this is a good moment to start experimenting with the modern Attinies supported by megaTinyCore.
You can still use them in a breadboard of you solder them on a DIP adapter plate.
I am getting rid of all my DIL packages as the pins are too fragile for experimenting.
This AT85 has been living on it's adapter plate in a drawer for years now. It has sustained an amount of abuse that would have cost his DIL brother all of it's legs.
I realized I overreacted when I received the notice and panicked. There are MANY components out there that have been on the "Not Recommended" list for years and are still available.
It's not JUST the tiny84 DIPs that are going EOL. Many DIP devices that are popular in the Arduino community are apparently getting axed, including the ATmega8a, ATmega168P, ATmega32A, and ATmega644P
