ATtiny85 Signature Failure
Hello everyone,
I've been trying to program an ATtiny85 using an Arduino UNO as an ISP, but I'm running into some issues.
Setup
  • Programmer: Arduino UNO as an ISP
  • Target: ATtiny85
  • Software: Arduino IDE 2.2.1
Settings:
  • Board: ATtiny25/45/85 (No bootloader)
  • Port: COM3
  • B.O.D. Level: B.O.D. Disabled (saves power)
  • Chip: ATtiny85
  • Clock Source: 8 MHz (internal)
  • Save EEPROM: EEPROM retained
  • LTO: Enabled
  • millis()/micros(): Enabled
  • Timer 1 Clock: CPU (CPU frequency)
  • Programmer: Arduino as ISP
Problem: When trying to burn the bootloader, I get the following error:
"C:\Users\razib\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18/bin/avrdude" "-CC:\Users\razib\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2/avrdude.conf" -v -pattiny85 -cstk500v1 -PCOM3 -b19200 -e -Uefuse:w:0xFF:m -Uhfuse:w:0b11010111:m -Ulfuse:w:0xE2:m "-Uflash:w:C:\Users\razib\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2/bootloaders/empty/empty_all.hex:i"
avrdude: Version 6.3-20201216
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\razib\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         Setting bit clk period        : 5.0
         AVR Part                      : ATtiny85
         Chip Erase delay              : 400000 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    12     4    0 no        512    4      0  4000  4500 0xff 0xff
           flash         65    12    32    0 yes      8192   64    128 30000 30000 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          2    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x00ff00
avrdude: Expected signature for ATtiny85 is 1E 93 0B
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
Failed chip erase: uploading error: exit status 1
I've ensured the following:
  • Proper connections between the UNO and the ATtiny85.
  • Added a capacitor between RESET and GND on the UNO.
  • The ATtiny85 is powered by the 5V output from the UNO during programming (USB power supply only).
I've followed standard guides and procedures for setting up the Arduino as an ISP, but still can't get past this issue. Any suggestions or insights would be greatly appreciated!
Thank you in advance for your help!
Are you using the ATTinyCore core?
Have you confirmed the integrity of the connections with a DMM?
Can you post a schematic and some photos of your wiring?
I have used an Uno with Arduino as ISP and AttinyCore to program many tiny85 chips with no problems.
I am using the AttinyCore boards, if that is what you mean.
I have confirmed the connections.
Photos and schematic will be posted later when I'm near the setup.
Did you buy the Attiny85 from a reputable source?
in the past i bought a few via Ebay and/or Aliexpress and bumped into a few that had their fuses set in a way that it was hard to program them.
  1. clocked from the internal 128KHz WDT timer.
    Then you are in luck, as the Arduino-ISP sketch has an option that you can uncomment
// Configure SPI clock (in Hz).
// E.g. for an ATtiny @ 128 kHz: the datasheet states that both the high and low
// SPI clock pulse must be > 2 CPU cycles, so take 3 cycles i.e. divide target
// f_cpu by 6:
//     #define SPI_CLOCK            (128000/6)  <<<<<<<< uncomment this one <<<<<<<<<
// A clock slow enough for an ATtiny85 @ 1 MHz, is a reasonable default:
#define SPI_CLOCK 		(1000000/6)    <<<<<<<<<<<<<<<<  delete this one  <<<<<<<<<<
  1. The reset pin was disabled.
    That took some more effort to overcome as I had to solder an HV programmer on top of my UNO to reprogram the Attiny to it's factory default.
The attiny was assembled by jlcpcb from lcsc so I think it's reputable.
I once bought one from AliExpress that turned out to be an attiny12 instead.
If the one I have now is what you said, how can I know that?
JLCPCB would be out of business soon if they become known for mounting fake components.
Are we by any chance talking about a PCB here that has other (passive) components connected to the PB0, PB1, PB2 pins? That may conflict with ISP programming.
Yes but it's a simple one so I scratched off all the traces leading outside to isolate the attiny
Here are the schematics and photos
The two blue traces on the left have been scratched off to isolate the attiny and the bottom dip switch has been turned off.
No passive components are connected anywhere except for a 10uF and a 100nF between GND and VCC.
these are the connections from the board to the UNO
this means the connections are:
UNO --- TINY
PC6 ----- PB5 (RED)
PB5 ----- PB2 (YELLOW)
PB4 ----- PB1 (BLUE)
GND ---- GND (TEAL)
PB3 ----- PB0 (PINK)
5V ------- VCC (WHITE-ISH)
I made sure the IC is oriented correctly.
UNO programmer code from example
// ArduinoISP
// Copyright (c) 2008-2011 Randall Bohn
// If you require a license, see
// https://opensource.org/licenses/bsd-license.php
// This sketch turns the Arduino into a AVRISP using the following Arduino pins:
// Pin 10 is used to reset the target microcontroller.
// By default, the hardware SPI pins MISO, MOSI and SCK are used to communicate
// with the target. On all Arduinos, these pins can be found
// on the ICSP/SPI header:
//               MISO °. . 5V (!) Avoid this pin on Due, Zero...
//               SCK   . . MOSI
//                     . . GND
// On some Arduinos (Uno,...), pins MOSI, MISO and SCK are the same pins as
// digital pin 11, 12 and 13, respectively. That is why many tutorials instruct
// you to hook up the target to these pins. If you find this wiring more
// practical, have a define USE_OLD_STYLE_WIRING. This will work even when not
// using an Uno. (On an Uno this is not needed).
// Alternatively you can use any other digital pin by configuring
// software ('BitBanged') SPI and having appropriate defines for PIN_MOSI,
// PIN_MISO and PIN_SCK.
// IMPORTANT: When using an Arduino that is not 5V tolerant (Due, Zero, ...) as
// the programmer, make sure to not expose any of the programmer's pins to 5V.
// A simple way to accomplish this is to power the complete system (programmer
// and target) at 3V3.
// Put an LED (with resistor) on the following pins:
// 9: Heartbeat   - shows the programmer is running
// 8: Error       - Lights up if something goes wrong (use red if that makes sense)
// 7: Programming - In communication with the target
#include "Arduino.h"
#undef SERIAL
#define PROG_FLICKER true
// f_cpu by 6:
#define SPI_CLOCK (1000000 / 6)
// Select hardware or software SPI, depending on SPI clock.
// Currently only for AVR, for other architectures (Due, Zero,...), hardware SPI
// is probably too fast anyway.
#if defined(ARDUINO_ARCH_AVR)
#if SPI_CLOCK > (F_CPU / 128)
#define USE_HARDWARE_SPI
#endif
#endif
// Configure which pins to use:
// The standard pin configuration.
#ifndef ARDUINO_HOODLOADER2
#define RESET 10  // Use pin 10 to reset the target rather than SS
#define LED_HB 9
#define LED_ERR 8
#define LED_PMODE 7
// Uncomment following line to use the old Uno style wiring
// (using pin 11, 12 and 13 instead of the SPI header) on Leonardo, Due...
// #define USE_OLD_STYLE_WIRING
#ifdef USE_OLD_STYLE_WIRING
#define PIN_MOSI 11
#define PIN_MISO 12
#define PIN_SCK 13
#endif
// HOODLOADER2 means running sketches on the ATmega16U2 serial converter chips
// on Uno or Mega boards. We must use pins that are broken out:
#else
#define RESET 4
#define LED_HB 7
#define LED_ERR 6
#define LED_PMODE 5
#endif
// By default, use hardware SPI pins:
#ifndef PIN_MOSI
#define PIN_MOSI MOSI
#endif
#ifndef PIN_MISO
#define PIN_MISO MISO
#endif
#ifndef PIN_SCK
#define PIN_SCK SCK
#endif
// Force bitbanged SPI if not using the hardware SPI pins:
#if (PIN_MISO != MISO) || (PIN_MOSI != MOSI) || (PIN_SCK != SCK)
#undef USE_HARDWARE_SPI
#endif
// Configure the serial port to use.
// Prefer the USB virtual serial port (aka. native USB port), if the Arduino has one:
//   - it does not autoreset (except for the magic baud rate of 1200).
//   - it is more reliable because of USB handshaking.
// Leonardo and similar have an USB virtual serial port: 'Serial'.
// Due and Zero have an USB virtual serial port: 'SerialUSB'.
// On the Due and Zero, 'Serial' can be used too, provided you disable autoreset.
// To use 'Serial': #define SERIAL Serial
#ifdef SERIAL_PORT_USBVIRTUAL
#define SERIAL SERIAL_PORT_USBVIRTUAL
#else
#endif
// Configure the baud rate:
#define BAUDRATE 19200
// #define BAUDRATE	115200
// #define BAUDRATE	1000000
#define HWVER 2
#define SWMAJ 1
#define SWMIN 18
// STK Definitions
#define STK_OK 0x10
#define STK_FAILED 0x11
#define STK_UNKNOWN 0x12
#define STK_INSYNC 0x14
#define STK_NOSYNC 0x15
#define CRC_EOP 0x20  //ok it is a space...
void pulse(int pin, int times);
#ifdef USE_HARDWARE_SPI
#include "SPI.h"
#else
#define SPI_MODE0 0x00
#if !defined(ARDUINO_API_VERSION) || ARDUINO_API_VERSION != 10001  // A SPISettings class is declared by ArduinoCore-API 1.0.1
class SPISettings {
public:
  // clock is in Hz
  SPISettings(uint32_t clock, uint8_t bitOrder, uint8_t dataMode)
    : clockFreq(clock) {
    (void)bitOrder;
    (void)dataMode;
  uint32_t getClockFreq() const {
    return clockFreq;
private:
  uint32_t clockFreq;
#endif                                                             // !defined(ARDUINO_API_VERSION)
class BitBangedSPI {
public:
  void begin() {
    digitalWrite(PIN_SCK, LOW);
    digitalWrite(PIN_MOSI, LOW);
    pinMode(PIN_SCK, OUTPUT);
    pinMode(PIN_MOSI, OUTPUT);
    pinMode(PIN_MISO, INPUT);
  void beginTransaction(SPISettings settings) {
    pulseWidth = (500000 + settings.getClockFreq() - 1) / settings.getClockFreq();
    if (pulseWidth == 0) {
      pulseWidth = 1;
  void end() {}
  uint8_t transfer(uint8_t b) {
    for (unsigned int i = 0; i < 8; ++i) {
      digitalWrite(PIN_MOSI, (b & 0x80) ? HIGH : LOW);
      digitalWrite(PIN_SCK, HIGH);
      delayMicroseconds(pulseWidth);
      b = (b << 1) | digitalRead(PIN_MISO);
      digitalWrite(PIN_SCK, LOW);  // slow pulse
    return b;
private:
  unsigned long pulseWidth;  // in microseconds
static BitBangedSPI SPI;
#endif
  SERIAL.begin(BAUDRATE);
  pinMode(LED_PMODE, OUTPUT);
  pulse(LED_PMODE, 2);
  pinMode(LED_ERR, OUTPUT);
  pulse(LED_ERR, 2);
  pinMode(LED_HB, OUTPUT);
  pulse(LED_HB, 2);
int ISPError = 0;
int pmode = 0;
// address for reading and writing, set by 'U' command
unsigned int here;
uint8_t buff[256];  // global block storage
#define beget16(addr) (*addr * 256 + *(addr + 1))
typedef struct param {
  uint8_t devicecode;
  uint8_t revision;
  uint8_t progtype;
  uint8_t parmode;
  uint8_t polling;
  uint8_t selftimed;
  uint8_t lockbytes;
  uint8_t fusebytes;
  uint8_t flashpoll;
  uint16_t eeprompoll;
  uint16_t pagesize;
  uint16_t eepromsize;
  uint32_t flashsize;
} parameter;
parameter param;
// this provides a heartbeat on pin 9, so you can tell the software is running.
uint8_t hbval = 128;
int8_t hbdelta = 8;
void heartbeat() {
  static unsigned long last_time = 0;
  unsigned long now = millis();
  if ((now - last_time) < 40) {
    return;
  last_time = now;
  if (hbval > 192) {
    hbdelta = -hbdelta;
  if (hbval < 32) {
    hbdelta = -hbdelta;
  hbval += hbdelta;
  analogWrite(LED_HB, hbval);
static bool rst_active_high;
void reset_target(bool reset) {
  digitalWrite(RESET, ((reset && rst_active_high) || (!reset && !rst_active_high)) ? HIGH : LOW);
void loop(void) {
  // is pmode active?
  if (pmode) {
    digitalWrite(LED_PMODE, HIGH);
    digitalWrite(LED_PMODE, LOW);
  // is there an error?
  if (ISPError) {
    digitalWrite(LED_ERR, HIGH);
    digitalWrite(LED_ERR, LOW);
  // light the heartbeat LED
  heartbeat();
  if (SERIAL.available()) {
    avrisp();
uint8_t getch() {
  while (!SERIAL.available())
  return SERIAL.read();
void fill(int n) {
  for (int x = 0; x < n; x++) {
    buff[x] = getch();
#define PTIME 30
void pulse(int pin, int times) {
  do {
    digitalWrite(pin, HIGH);
    delay(PTIME);
    digitalWrite(pin, LOW);
    delay(PTIME);
  } while (times--);
void prog_lamp(int state) {
  if (PROG_FLICKER) {
    digitalWrite(LED_PMODE, state);
uint8_t spi_transaction(uint8_t a, uint8_t b, uint8_t c, uint8_t d) {
  SPI.transfer(a);
  SPI.transfer(b);
  SPI.transfer(c);
  return SPI.transfer(d);
void empty_reply() {
  if (CRC_EOP == getch()) {
    SERIAL.print((char)STK_INSYNC);
    SERIAL.print((char)STK_OK);
    ISPError++;
    SERIAL.print((char)STK_NOSYNC);
void breply(uint8_t b) {
    SERIAL.print((char)b);
    ISPError++;
void get_version(uint8_t c) {
  switch (c) {
    case 0x80:
      breply(HWVER);
    case 0x81:
      breply(SWMAJ);
    case 0x82:
      breply(SWMIN);
    case 0x93:
      breply('S');  // serial programmer
    default:
      breply(0);
void set_parameters() {
  // call this after reading parameter packet into buff[]
  param.devicecode = buff[0];
  param.revision = buff[1];
  param.progtype = buff[2];
  param.parmode = buff[3];
  param.polling = buff[4];
  param.selftimed = buff[5];
  param.lockbytes = buff[6];
  param.fusebytes = buff[7];
  param.flashpoll = buff[8];
  // ignore buff[9] (= buff[8])
  // following are 16 bits (big endian)
  param.eeprompoll = beget16(&buff[10]);
  param.pagesize = beget16(&buff[12]);
  param.eepromsize = beget16(&buff[14]);
  // 32 bits flashsize (big endian)
  param.flashsize = buff[16] * 0x01000000
                    + buff[17] * 0x00010000
                    + buff[18] * 0x00000100
                    + buff[19];
  // AVR devices have active low reset, AT89Sx are active high
  rst_active_high = (param.devicecode >= 0xe0);
void start_pmode() {
  // Reset target before driving PIN_SCK or PIN_MOSI
  // SPI.begin() will configure SS as output, so SPI master mode is selected.
  // We have defined RESET as pin 10, which for many Arduinos is not the SS pin.
  // So we have to configure RESET as output here,
  // (reset_target() first sets the correct level)
  reset_target(true);
  pinMode(RESET, OUTPUT);
  SPI.begin();
  SPI.beginTransaction(SPISettings(SPI_CLOCK, MSBFIRST, SPI_MODE0));
  // See AVR datasheets, chapter "SERIAL_PRG Programming Algorithm":
  // Pulse RESET after PIN_SCK is low:
  delay(20);  // discharge PIN_SCK, value arbitrarily chosen
  reset_target(false);
  // Pulse must be minimum 2 target CPU clock cycles so 100 usec is ok for CPU
  // speeds above 20 KHz
  delayMicroseconds(100);
  reset_target(true);
  // Send the enable programming command:
  delay(50);  // datasheet: must be > 20 msec
  spi_transaction(0xAC, 0x53, 0x00, 0x00);
  pmode = 1;
void end_pmode() {
  SPI.end();
  // We're about to take the target out of reset so configure SPI pins as input
  pinMode(PIN_MOSI, INPUT);
  pinMode(PIN_SCK, INPUT);
  pinMode(RESET, INPUT);
  pmode = 0;
void universal() {
  uint8_t ch;
  fill(4);
  ch = spi_transaction(buff[0], buff[1], buff[2], buff[3]);
  breply(ch);
void flash(uint8_t hilo, unsigned int addr, uint8_t data) {
  spi_transaction(0x40 + 8 * hilo,
                  addr >> 8 & 0xFF,
                  addr & 0xFF,
                  data);
void commit(unsigned int addr) {
  if (PROG_FLICKER) {
    prog_lamp(LOW);
  spi_transaction(0x4C, (addr >> 8) & 0xFF, addr & 0xFF, 0);
  if (PROG_FLICKER) {
    delay(PTIME);
    prog_lamp(HIGH);
unsigned int current_page() {
  if (param.pagesize == 32) {
    return here & 0xFFFFFFF0;
  if (param.pagesize == 64) {
    return here & 0xFFFFFFE0;
  if (param.pagesize == 128) {
    return here & 0xFFFFFFC0;
  if (param.pagesize == 256) {
    return here & 0xFFFFFF80;
  return here;
void write_flash(int length) {
  fill(length);
    SERIAL.print((char)write_flash_pages(length));
    ISPError++;
uint8_t write_flash_pages(int length) {
  int x = 0;
  unsigned int page = current_page();
  while (x < length) {
    if (page != current_page()) {
      commit(page);
    flash(LOW, here, buff[x++]);
    flash(HIGH, here, buff[x++]);
    here++;
  commit(page);
  return STK_OK;
#define EECHUNK (32)
uint8_t write_eeprom(unsigned int length) {
  // here is a word address, get the byte address
  unsigned int start = here * 2;
  unsigned int remaining = length;
  if (length > param.eepromsize) {
    ISPError++;
    return STK_FAILED;
  while (remaining > EECHUNK) {
    write_eeprom_chunk(start, EECHUNK);
    start += EECHUNK;
    remaining -= EECHUNK;
  write_eeprom_chunk(start, remaining);
  return STK_OK;
// write (length) bytes, (start) is a byte address
uint8_t write_eeprom_chunk(unsigned int start, unsigned int length) {
  // this writes byte-by-byte, page writing may be faster (4 bytes at a time)
  fill(length);
  prog_lamp(LOW);
  for (unsigned int x = 0; x < length; x++) {
    unsigned int addr = start + x;
    spi_transaction(0xC0, (addr >> 8) & 0xFF, addr & 0xFF, buff[x]);
    delay(45);
  prog_lamp(HIGH);
  return STK_OK;
void program_page() {
  char result = (char)STK_FAILED;
  unsigned int length = 256 * getch();
  length += getch();
  char memtype = getch();
  // flash memory @here, (length) bytes
  if (memtype == 'F') {
    write_flash(length);
    return;
  if (memtype == 'E') {
    result = (char)write_eeprom(length);
      SERIAL.print(result);
      ISPError++;
    return;
  SERIAL.print((char)STK_FAILED);
  return;
uint8_t flash_read(uint8_t hilo, unsigned int addr) {
  return spi_transaction(0x20 + hilo * 8,
                         (addr >> 8) & 0xFF,
                         addr & 0xFF,
                         0);
char flash_read_page(int length) {
  for (int x = 0; x < length; x += 2) {
    uint8_t low = flash_read(LOW, here);
    SERIAL.print((char)low);
    uint8_t high = flash_read(HIGH, here);
    SERIAL.print((char)high);
    here++;
  return STK_OK;
char eeprom_read_page(int length) {
  // here again we have a word address
  for (int x = 0; x < length; x++) {
    uint8_t ee = spi_transaction(0xA0, (addr >> 8) & 0xFF, addr & 0xFF, 0xFF);
    SERIAL.print((char)ee);
  return STK_OK;
void read_page() {
  length += getch();
  if (CRC_EOP != getch()) {
    ISPError++;
    return;
    result = flash_read_page(length);
    result = eeprom_read_page(length);
void read_signature() {
    ISPError++;
    return;
  uint8_t high = spi_transaction(0x30, 0x00, 0x00, 0x00);
  uint8_t middle = spi_transaction(0x30, 0x00, 0x01, 0x00);
  SERIAL.print((char)middle);
  uint8_t low = spi_transaction(0x30, 0x00, 0x02, 0x00);
void avrisp() {
  uint8_t ch = getch();
  switch (ch) {
    case '0':  // signon
      ISPError = 0;
      empty_reply();
    case '1':
      if (getch() == CRC_EOP) {
        SERIAL.print("AVR ISP");
        ISPError++;
    case 'A':
      get_version(getch());
    case 'B':
      fill(20);
      set_parameters();
      empty_reply();
    case 'E':  // extended parameters - ignore for now
      fill(5);
      empty_reply();
    case 'P':
      if (!pmode) {
        start_pmode();
      empty_reply();
    case 'U':  // set address (word)
      here = getch();
      here += 256 * getch();
      empty_reply();
    case 0x60:  //STK_PROG_FLASH
      getch();  // low addr
      getch();  // high addr
      empty_reply();
    case 0x61:  //STK_PROG_DATA
      getch();  // data
      empty_reply();
    case 0x64:  //STK_PROG_PAGE
      program_page();
    case 0x74:  //STK_READ_PAGE 't'
      read_page();
    case 'V':  //0x56
      universal();
    case 'Q':  //0x51
      ISPError = 0;
      end_pmode();
      empty_reply();
    case 0x75:  //STK_READ_SIGN 'u'
      read_signature();
    // expecting a command, not CRC_EOP
    // this is how we can get back in sync
    case CRC_EOP:
      ISPError++;
    // anything else we will return STK_UNKNOWN
    default:
      ISPError++;
        SERIAL.print((char)STK_UNKNOWN);
The reset pin from your tiny should go to pin 10 on the UNO (PB2)
You now have it connected to the reset pin (PC6) of the UNO.
Thank you so much!!! this worked :slight_smile:
