Attiny88 Development Board Problem
Hi, I decided to do wireless button box with using attiny88 development board as a transmitter, arduino pro micro as a receiver. Both of them use NRF24L01 for communication. I also use breakout adapter for NRF24L01. I saw the project from this video. I found 16 differents pins on the attiny88 board for my 16 buttons. I tested, each of them work properly one by one but when I write the code for 16 pins, somethings wrong. None of them work. The codes I mentioned are like this in the code, {4, "97"}, {5, "98"}, {6, "99"}, {7, "100"}. It works fine when I reduce the number of buttons in the code to 9 or less. I do not understand what is wrong. I used attinycore micronucleus mh-et t88 board manager. I cannot try different board manager like attinycore no bootloader or optiboot version because they do not see attiny88 board. Could you help me? What should I do?
Code for receiver
#include "SPI.h"
#include "RF24.h"
#include <Keyboard.h>
#define CE_PIN 5
#define CSN_PIN 6
RF24 radio(CE_PIN, CSN_PIN);
uint8_t ADDRESS[6] = "CKeyB";
// Maximum number of keys a shortcut can be, or max number of keys to send through the NRF24L01 per button.
// This needs to match with the transmitter side.
const int MAX_SHORTCUT_KEYS = 4;
const int BTN_SHORTCUT_SIZE = (3 * MAX_SHORTCUT_KEYS) + (MAX_SHORTCUT_KEYS - 1) + 1;
char btnShortcut[BTN_SHORTCUT_SIZE];
char * key;
int keyInt;
void initRadio() {
    if (!radio.begin()) {
        while (1) {}
    radio.setPALevel(RF24_PA_LOW);
    radio.setPayloadSize(BTN_SHORTCUT_SIZE);
    radio.openReadingPipe(1, ADDRESS);
    radio.setDataRate(RF24_1MBPS);
    radio.startListening();
    Keyboard.begin();
    initRadio();
    if (radio.available()) {
        radio.read(&btnShortcut, sizeof(btnShortcut));
        // Excract each key integer value from the incoming string and press each button.
        key = strtok(btnShortcut, " ");
        while(key != NULL) {
            keyInt = atoi(key);
            Keyboard.press(keyInt);
            key = strtok(NULL, " ");
        delay(20);
        Keyboard.releaseAll();
Code for transmitter
#include "SPI.h"
#include "RF24.h"
#include <Button.h>
// Radio, choose any pins on your micro-controller to use as the CE and CSN pins.
#define CE_PIN 3
#define CSN_PIN 7
const uint8_t ADDRESS[6] = "CKeyB";
// This needs to match with the receiver side.
struct ButtonInfo {
    int btnPin;
// All keys are represented using their ASCII decimal/int value. This can be found here: www.asciitable.com
// First specify the pin number, then seperate each key for that button in a string by a space.
const ButtonInfo BUTTONS_INFO[] = {{4, "97"},
                                   {5, "98"},
                                   {6, "99"},
                                   {8, "100"},
                                   {9, "101"},
                                   {14, "102"},
                                   {15, "103"},
                                   {16, "104"},
                                   {17, "105"},
                                   {18, "106"},
                                   {19, "107"},
                                   {20, "108"},
                                   {21, "109"},
                                   {22, "110"},
                                   {23, "111"},
                                   {24, "112"},
const int N_BUTTONS = sizeof(BUTTONS_INFO) / sizeof(BUTTONS_INFO[0]);
const uint16_t DEBOUNCE_MS = 10;
Button *buttonObjs[N_BUTTONS];
void initRadio() {
        while (1) {}
    radio.openWritingPipe(ADDRESS);
    radio.stopListening();
void initButtons() {
    for(int i = 0; i < N_BUTTONS; i++) {
        ButtonInfo btnInfo = BUTTONS_INFO[i];
        buttonObjs[i] = new Button(btnInfo.btnPin, DEBOUNCE_MS);
        buttonObjs[i] -> begin();
    initRadio();
    initButtons();
    // If any button pressed, then send the button keys through radio using the nRF24L01.
        if(buttonObjs[i] -> pressed()) {
            radio.write(&btnInfo.btnShortcut, sizeof(btnInfo.btnShortcut));
I will guess the problem is in your wiring.
Show your wiring, and show a schematic drawing.
It seems to me that you exceeded the max payload of NRF24.
The maximum payload size of the NRF24 protocol is 32 bytes.
But it not understandable for me, why you need the payload for all buttons at once, if you send the buttons one by one.
Thanks for your reply. I can show wiring if you want but I do not think wiring is the problem. When I remove any 7 buttons randomly from the code, it works fine. Wiring was still same with before removing them.
I do not actually want them all to work at the same time. I want to use totally 16 different buttons one by one. Is the code in the project prepared for all of them to work at the same time? I do not know much about coding.
Edit: The problem was related to the maximum payload of NRF24, as you said. It was fixed by reducing the number of max shortcut keys. Thanks for your replies and opinions. :slightly_smiling_face:
