I've been doing a research on finding a cheap small and useful audio module with micro
sd card for arduino. I bought in the past a audio module a WTV one you can see it in the pic.
bellow.
but this module had many and many problems which required resoldering, specific programming
and not available library or something useful that could help. I was a beginner back then and
that was a bit of pain to work with that kind of modules.
So after all that time I want to give a 2nd try to work and do a small project which require
such module, I done google research and I found many but I wanted to give a try here
in the audio section forum to see if you got any good modules that you can suggest me to use
and easy to work with them.
D.60
