Im currently creating a project where I can tune a guitar using servo motors and a frequency sensing circuit.
The code below is what im using for now:
#include <avr/io.h>
#include <avr/interrupt.h>
//analog guitar signal input
int guitarInput = A0;
//LED inputs
int led_high = 13;
int led_ok = 12;
int led_low = 11;
int led_e4 = 10;
int led_b3 = 9;
int led_g3 = 8;
int led_d3 = 7;
int led_a2 = 6;
int led_e2 = 5;
//string selection
int button_pin = 3; //button pin
int string_select;
int select_pin_val;
//Mic Variables
int inputPin = A0;
byte inputValue;
const unsigned int len = 500;
volatile unsigned int data[len];
volatile int count = 0;
const double sample_freq = 6400;
//Frequency Variables
float Frequency = 0;
float lastFrequency = 0;
float URange = 0;
float LRange = 0;
float targetFreq = 0;
//Servo
int servoPin = 2; // control pin for servo motor
//Timer
long timer;
int idle_timer;
timer = 0; // 1/6400 second
pinMode(inputPin, INPUT);
//setup timing and frequency measuring
cli();
TCCR1A = 0;
TCCR1B = 0;
//set compare match register to desired timer count
//Value = (time between interrupts / 0.0000000625)s - 1
OCR1A = 2499;
TCCR1B |= (1 << WGM12);
TCCR1B |= (1 << CS10);
TIMSK1 |= (1 << OCIE1A);
// //setup low pass filter
// // filters out changes faster that 5 Hz.
// float filterFrequency = 400.0;
// // create a one pole (RC) lowpass filter
// FilterOnePole lowpassFilter(LOWPASS, filterFrequency);
//Set the input and output pins
pinMode(button_pin, INPUT);
pinMode(servoPin, OUTPUT);
pinMode(led_high, OUTPUT);
pinMode(led_ok, OUTPUT);
pinMode(led_low, OUTPUT);
pinMode(led_e4, OUTPUT);
pinMode(led_b3, OUTPUT);
pinMode(led_g3, OUTPUT);
pinMode(led_d3, OUTPUT);
pinMode(led_a2, OUTPUT);
pinMode(led_e2, OUTPUT);
sei();
Serial.begin(9600); //reenable interrupts
// Nothing is done in the loop
// interrupt service routine every microsecond
ISR(TIMER1_COMPA_vect)
timer++;
//// Read button press to determine which string is to be detected
// if (timer % 1000 == 0)
// select_pin_val = digitalRead(button_pin);
// if (select_pin_val == HIGH)
// string_select = ((string_select + 1) % 6);
// Serial.print("string: ");
// Serial.println(string_select);
//get signal data and store to array, process every 600 samples
data[count] = analogRead(inputPin);
// Serial.println(data[count]);
count ++;
if (count == len)
count = 0;
freqFind();
//ALL LEDS OFF
digitalWrite(led_e4, LOW); // sets the proper LED on, all else off
digitalWrite(led_b3, LOW);
digitalWrite(led_g3, LOW);
digitalWrite(led_d3, LOW);
digitalWrite(led_a2, LOW);
digitalWrite(led_e2, LOW);
// Depending on which string is selected, the proper variables are set
switch (string_select)
case 0: //LOW E STRING
digitalWrite(led_e2, HIGH);
targetFreq = 105.41;
URange = targetFreq + 30;
LRange = targetFreq - 30;
case 1: //A STRING
digitalWrite(led_a2, HIGH);
targetFreq = 141.00;
case 2: //D STRING
digitalWrite(led_d3, HIGH);
targetFreq = 184.83;
case 3: //G STRING
digitalWrite(led_g3, HIGH);
targetFreq = 245.00;
case 4: //B STIRNG
digitalWrite(led_b3, HIGH);
targetFreq = 315.94;
case 5: //HIGH E STRING
digitalWrite(led_e4, HIGH);
targetFreq = 414;
// After the string input has been idle for a while, we take the average of a number of cross counts that were in bound.
if (idle_timer >= 3000)
Serial.println("Chillin");
void tune(float average)
//allowable +/-
float max_allowable = 4.0;
float min_allowable = 4.0;
digitalWrite(led_high, LOW);
digitalWrite(led_ok, LOW);
digitalWrite(led_low, LOW);
// cli(); //disable interrupts
if (average > targetFreq + 2)
Serial.println(" TOO HIGH");
tooHigh(average - targetFreq);
else if (average < targetFreq -2)
Serial.println(" TOO LOW");
tooLow(targetFreq - average);
Serial.println(" JUST RIGHT");
OK();
void OK()
int currentString = string_select;
digitalWrite(led_ok, HIGH);
Serial.println("ONTO THE NEXT STRING!!");
//move onto next string
void tooLow(float difference)
Serial.print(" DIFFERENCE: ");
Serial.println(difference);
digitalWrite(led_low, HIGH);
turnCCW(difference);
void tooHigh(float difference)
digitalWrite(led_high, HIGH);
turnCW(difference);
//1 HZ = 7.5 degrees
void turnCW(float difference)
double angle = difference*.1;
double pulseWidth = (angle * 10 ) + 600;
for(long i = 0; i < difference * 100; i++)
digitalWrite(servoPin, HIGH); // start the pulse
delayMicroseconds(pulseWidth); // pulse width
digitalWrite(servoPin, LOW); // stop the pulse
void turnCCW(float difference)
float freqFind()
static float count = 0;
static float avgsum = 0;
float average;
double sum = 0;
int thresh = 0;
byte pd_state = 0;
double period = 0;
long sum_old;
double freq_per = 0;
int k, i;
// Autocorrelation
for (int i=0; i < len && (pd_state != 3); i++)
sum_old = sum;
sum = 0;
for (k=0; k <len-i; k++)
sum += (data[k]) * (data[k+i]);
sum /= k ;
// Peak Detect State Machine
// 0: initial, set threshold
// 1: detect positive slope
// 2: detect negative slope
// 3: peak found
if (pd_state == 0)
thresh = sum / 2;
pd_state = 1;
else if (pd_state == 1 && (sum > thresh) && (sum - sum_old) > 0)
pd_state = 2;
else if (pd_state == 2 && (sum - sum_old) <= 0)
period = i;
pd_state = 3;
freq_per = sample_freq*1.036/period;
//if idling
if (freq_per < 10)
idle_timer++;
else if(freq_per > LRange && freq_per < URange)
// Frequency identified in Hz
Serial.println("Value Caputured");
avgsum += freq_per;
count += 1;
idle_timer = 0;
Serial.println(freq_per);
if (count == 2)
average = avgsum/count;
Serial.print(" Average Frequency: ");
Serial.print("\t");
Serial.println(average);
Serial.print(" Target Frequency: ");
Serial.print("\t");
Serial.println(targetFreq);
//LED indicate sample complete
delay(100);
cli();//disable interrupts
//TUNE THE GUITAR!
tune(average);
sei(); //reenable interrupts
//reset counter variables
count = 0;
avgsum = 0;
return(average);
My question is why are the libraries included in the code not working? They must be in orange color text right? what am I doing wrong? Plus I cant find any of the libraries used in the code that are downloadable online.
