Autoranging Ohmmeter
Note: before i explain my issue i would like to note that I am a beginner in electronics please pay attention to that when providing solutions and explanations. Thank you.
I have succeeded at making an auto raging Ohmmeter it is still ofcours experimental there for I would like to get some opinions and perhaps solutions to some of the issues I’m facing
How it works:
It is based on a simple voltage divider. After experimenting it seems that a voltage drop across the unknown resistor in a certain range (this case [3.135V, 0.99V] with a voltage source equal to 3.3V) gives the most precise results compared to other values.
This Ohmmeter has a very useful feature and that is auto ranging, it changes the range automatically when the voltage drop values are not in the previously mentioned interval ([3.135V, 0.99V]).
The accompanied image shows how the device works.
If the value of Rx is too small compared to (R1+R2+R3) the Arduino switches the analog reading from A0 to A1 if the problem still accurse the Arduino will change again to A2 meaning it is now measuring not the value of Rx but (Rx+R1+R2) in series after that the Arduino is programmed to do the subtraction accordingly
This device presents some noticeable inconvenient that need to be eliminated:
1- It depends on experimental values, so it is not certain if it’ll function properly in different conditions.
2- For accurate (still not exact) measurements the value of Rx has to be greater than R1
3- It provides acceptable measurements compared to the actual value with an error that is not too big (less than 1% relative error) the precision was obtained by the use of some of the arduino functions (such as voltage reference, and responsive analog read to make it more stable) also I have chosen the voltage source to be 3.3V instead of 5V to reduce noise, now if one wishes to use a different microcontroller other than arduino will it still be possible to obtain the same precision.
I would like to know your professional opinion regarding these inconvenient and if you may solutions for them, I have accompanied the code for better understanding.
Thank you
#include <ResponsiveAnalogRead.h>
ResponsiveAnalogRead analogPin0(A0, true);
ResponsiveAnalogRead analogPin1(A1, true);
ResponsiveAnalogRead analogPin2(A2, true);
int raw1= 0,raw2=0,raw3=0;
int Vin= 3.3;
float Vout1= 0,Vout2=0,Vout3=0;
float R1= 10000,R2=100000,R3=1000000;
float Rx= 0;
float buffer= 0;
analogReference(EXTERNAL);
analogPin0.update();
analogPin1.update();
analogPin2.update();
raw1=analogPin0.getValue();
buffer= raw1 * Vin;
Vout1= (buffer)/1024.0;
if(Vout1<=3.135&&Vout1>=0.99) //firstif
buffer= (Vin/Vout1) -1;
Rx= (R1+R2+R3) * buffer;
Serial.print("Vout1: ");
Serial.println(Vout1);
Serial.print("Rx: ");
Serial.println(Rx);
else //else1 of first if
raw2=analogPin1.getValue();
buffer= raw2 * Vin;
Vout2= (buffer)/1024.0;
if(Vout2<=3.135&&Vout2>=0.99) //second if of first else
buffer= (Vin/Vout2) -1;
Rx= (R2+R3) * buffer;
Rx=Rx-R1;
Serial.print("Vout2: ");
Serial.println(Vout2);
Serial.println(Rx);
raw3=analogPin2.getValue();
buffer= raw3 * Vin;
Vout3= (buffer)/1024.0;
if(Vout3<=3.135&&Vout3>=0.99)
buffer= (Vin/Vout3) -1;
Rx= R3 * buffer;
Rx=Rx-(R1+R2);
Serial.print("Vout3: ");
Serial.println(Vout3);
Serial.println(Rx);
What happends to the low voltage reader, A0, when You apply the highest possible voltage read by A2? Look out for over voltage on A0.
Please attach a wiring diagram.
