AVRDude Error: address 0x820003 out of range at line 2488
I want to flash a .hex file on Arduino Mega using AVRDude.
I ran this command:
avrdude -v -patmega2560 -c wiring -P /dev/ttyACM3 -b 115200 -D -U flash:w:"/address of file.hex":i
and got this error:
ERROR: address 0x820003 out of range at line 2488 of address of file.hex
What should I do? Please guide.
How was the HEX file generated?
This topic has a plausible explanation: process - Contiki compile error, " ERROR: address 0x820003 out of range at line 1740 of..." - Stack Overflow and if you generated the HEX file yourself it provides a solution.
Thank you for the link but I am too dumb to understand it.
NECTO Studio IDE created the .hex file and I am using AVRDude to flash it onto the Arduino Mega.
I want to connect NBIoT 5 click module of Mikroe to Arduino.
I suspect that you have to try https://forum.mikroe.com/ and ask the question there. It's a matter of configuration / passing the correct arguments to avr-objcopy but I can't tell you if you can influence that.
They also have a helpdesk, I guess for paying customers.
Thank you!
Will do just that.
