Arduino: 1.8.16 (Mac OS X), Board: "Arduino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/Users/christyyau/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/christyyau/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem11201 -b115200 -D -Uflash:w:/var/folders/b3/y_g3drns0rn7hml6sn82s3jr0000gn/T/arduino_build_400066/sketch_sep09a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/christyyau/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/christyyau/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
An error occurred while uploading the sketch
Using Port : /dev/cu.usbmodem11201
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "/dev/cu.usbmodem11201": No such file or directory
avrdude done. Thank you.
option enabled in File -> Preferences.
