avrdude. Invalid device signature. Programming ATTiny85 with Mega 2560
Hi!
I get always the error:
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
When programming an ATTiny85 with and Arduino Mega2560 R3. Attached is the picture of the wiring, I followed this wiring:
ATtiny Pin 1: Pin 53 ATtiny Pin 8: VCC
ATtiny Pin 2: S/C ATtiny Pin 7: Pin 52
ATtiny Pin 3: S/C ATtiny Pin 6: Pin 50
ATtiny Pin 4: GND ATtiny Pin 5: Pin 51
10 uF capacitor + to Reset of Mega, - to GND.
Here is the detailed output:
Using Port : COM11
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATtiny25
Chip Erase delay : 4500 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 6 4 0 no 128 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 2048 32 64 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x000000 (retrying)
Ha ocurrido un error mientras se enviaba el sketch
this check.
avrdude done. Thank you.
The sketch I try to upload is this one:
int led = 3;
pinMode(led, OUTPUT);
digitalWrite(led, HIGH);
digitalWrite(led, LOW);
Configuration for the boards is attached.
Any ideas? Thanks!
(deleted)
Thanks!
Tried pin 10 instead pin 53 of Mega but same error.
BTW I have selected by mistake ATTiny25 but now I corrected. Still the same error. Any other idea?
Here the output:
Using Port : COM11
AVR Part : ATtiny85
Chip Erase delay : 400000 us
PAGEL : P00
BS2 : P00
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
eeprom 65 12 4 0 no 512 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 8192 64 128 30000 30000 0xff 0xff
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
Reading | ################################################## | 100% 0.02s
Reading | ################################################## | 100% 0.04s
this check.
So the issue persists. Has anyone any idea on how to solve it? Thanks!
Well, I tried to put external cristal and the -F option as suggested by the software but it doesn´t work neither.
I tried also to burn the boatloader but I get this output:
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -v -v -v -pattiny85 -cstk500v1 -PCOM11 -b19200 -e -Uefuse:w:0xff:m -Uhfuse:w:0xdf:m -Ulfuse:w:0xf1:m
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM11
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATtiny85
PAGEL : P00
BS2 : P00
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82] [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98] [20]
avrdude: Recv: . [00]
Hardware Version: 2
Topcard : Unknown
avrdude: Send: A [41] . [84] [20]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Send: B [42] . [14] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] @ [40] . [02] . [00] . [00] . [00] [20] . [00] [20]
avrdude: PAGEL and BS2 signals not defined in the configuration file for part ATtiny85, using dummy values
avrdude: Send: E [45] . [05] . [04] . [d7] . [a0] . [01] [20]
avrdude: Send: P [50] [20]
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00] [20]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00] [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00] [20]
this check.
avrdude: Send: Q [51] [20]
Error burning downloader
So can you help me with this please? Thanks!
Hi again!
So there are some good advancements. I changed my arduino Mega 2560 for an arduino nano and now it both burns the bootloader and the sketch to the ATTiny85.
I used these instructions: Programming ATtiny85 using Arduino Nano as ISP (forums.4fips.com)
The only little thing is that the LED does not blink...
As this is now a different topic, I will post a new one with the current topic. Thanks!
did you get this working? i'm doing the same and having the same problem.
can i just use the icsp header to connect to the pins to attiny?
Has any one managed to solve the problem invalid device signature using Arduino Mega 2560
...bad i also have the same problem to program attiny85 with arduino mega 2560 and arduino software version 1.8.2..
this check.
????-I spent 2 days reading on the net........
That message means you have either connected the wires wrong or have set fuses to use a crystal when no crystal is connected (or have in fact selected a different chip than the one you're trying to program)
grazie DrAzzy...ho sostituito il (trinket con attiny 85), inserendo un modulo trinket uguale e usando arduino nano come programmer ISP.....( tiny85...16mhz external)...al primo colpo ha funzionato tutto e posso caricare sul trinket qualsiasi sketch.
Ma inserendo sui connettori il modulo precedente , arduino risponde sempre col messaggio che ho postato in precedenza. C'e' un altro modo per resuscitare l'attiny85?
Grazie a voi!
thanks to DrAzzy ... I replaced the (trinket with attiny 85), inserting a trinket equal module and using arduino nanof as ISP programmer ..... (tiny85 ... 16mhz external) ... at first shot everything worked I can load any sketch on the trinket.
But by inserting on the connectors the previous module, arduino always responds with the message I posted earlier. Is there another way to revive the attiny85?
Thanks to you!
finally reading here I understood everything !!
bye!!
I have same issue. With IDE 1.8.2 not apple to burn bootloader.
Solution was to upload first old IDE 1.6.3 ArduinoISP -> After that burning succesfully with IDE 1.8.2
-Jukka
