Hi, I´ye been using nanos for ages and recently saw some with usb-c (clones) and had to have them. But now, usb-c or normal micro, I get this error when uploading a sketch, seems that avrdude can´t communicate to the thing, USB-C or mini... what's going on?
Der Sketch verwendet 5064 Bytes (17%) des Programmspeicherplatzes. Das Maximum sind 28672 Bytes.
Globale Variablen verwenden 457 Bytes (17%) des dynamischen Speichers, 2103 Bytes für lokale Variablen verbleiben. Das Maximum sind 2560 Bytes.
Ein 1200bps-Reset wird auf dem seriellen Port /dev/cu.PT-P710BT0654 durchgeführt
Warten auf Upload-Port ...
Kein Upload-Port gefunden, verwende /dev/cu.PT-P710BT0654 stattdessen
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/phil/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
"/Users/phil/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude" "-C/Users/phil/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega32u4 -cavr109 "-P/dev/cu.PT-P710BT0654" -b57600 -D "-Uflash:w:/Users/phil/Library/Caches/arduino/sketches/730DE222CA186E3654B944E33E6241FE/flaschen_deckel.ino.hex:i"
User configuration file is "/Users/phil/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.PT-P710BT0654
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = ""; type =
Software Version = .�; Hardware Version = �.
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
avrdude done. Thank you.
Fehlgeschlagenes Hochladen: Hochladefehler: exit status 1
