avrdude: verification error; content mismatch
Sehr geehrte Damen und Herren,
mein Arduino(Mega2560)-Board scheint es
derzeit nicht so gut zu gehen. Anbei zwei
Logfiles:
  1. Hochladen eines Sketches
  2. Bootloader Brennversuch
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Users\mindcode\Desktop\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM17
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 43.5 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9801
avrdude: reading input file "C:\Users\mindcode\AppData\Local\Temp\build5084444692791622161.tmp/sketch_jul14a.cpp.hex"
avrdude: writing flash (642 bytes):
Writing | ################################################## | 100% 0.09s
avrdude: 642 bytes of flash written
avrdude: verifying flash memory against C:\Users\mindcode\AppData\Local\Temp\build5084444692791622161.tmp/sketch_jul14a.cpp.hex:
avrdude: load data flash data from input file C:\Users\mindcode\AppData\Local\Temp\build5084444692791622161.tmp/sketch_jul14a.cpp.hex:
avrdude: input file C:\Users\mindcode\AppData\Local\Temp\build5084444692791622161.tmp/sketch_jul14a.cpp.hex contains 642 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.09s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0x14 != 0x71
avrdude done. Thank you.
Using Port : COM17
Using Programmer : stk500v1
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Probleme beim Hochladen auf die Platine. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload .
Lassen Sie mich noch zum Schluss bemerken,
dass es dem Board vor ein paar Stunden noch gut ging!
Mit freundlichen Grüßen,
Mind Code
Haben Sie einen ISP-Programmierer? Welchen?
Grüße Uwe
Leider nicht. Nur einen anderen Arduino (Diesmal Due).
MindCode:
Dann kannst du auch keinen Bootloader brennen.
Oder du wartest bist du irgendwann mal ein anderes AVR Board hast:
