Hello, a few weeks ago I was looking for a code to make a basic calculator using Arduino uno, 16x2 LCD and a 4x4 keyboard but there were only things that were too basic and messy. I set myself the task of doing it on my own and I finally have a code with which it will work correctly, it makes accounts with decimal numbers if applicable and a cursor like in common calculators. Without further ado, I leave it here. Thank you ![]()
#include <Keypad.h>
#include <LiquidCrystal.h>
const byte ROWS = 4;
const byte COLS = 4;
char hexaKeys[ROWS][COLS] = {
{'1', '2', '3', '+'},
{'4', '5', '6', '-'},
{'7', '8', '9', '*'},
{'X', '0', '=', '/'}
byte rowPins[ROWS] = {3, 2, 1, 0};
byte colPins[COLS] = {7, 6, 5, 4};
LiquidCrystal lcd(9, 8, 10, 11, 12, 13);
Keypad myKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
boolean valorActual = false;
boolean siguiente = false;
boolean final = false;
String num1, num2, num3;
float resultado;
int movimiento;
char op;
int cursorPos = 0; // Cursor Position
unsigned long lastBlinkMillis = 0;
const int blinkInterval = 500; // Flashing interval
boolean cursorVisible = true;
boolean mostrarCursor = true; // Control to show/hide the cursor
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("ProyectBy");
lcd.setCursor(0, 1);
lcd.print("Gavan♡");
delay(1700);
lcd.clear();
char key = myKeypad.getKey();
if (key != NO_KEY && (key == '1' || key == '2' || key == '3' || key == '4' || key == '5' || key == '6' || key == '7' || key == '8' || key == '9' || key == '0')) {
if (valorActual != true) {
num1 = num1 + key;
int numLength = num1.length();
movimiento = numLength;
lcd.print(num1);
cursorPos = numLength; // Move the cursor +1
num2 = num2 + key;
int numLength = num2.length();
lcd.setCursor(movimiento + 1, 0);
lcd.print(num2);
cursorPos = movimiento + 1 + numLength; // Move the cursor +1
final = true;
} else if (valorActual == false && key != NO_KEY && (key == '/' || key == '*' || key == '-' || key == '+')) {
if (valorActual == false) {
valorActual = true;
op = key;
lcd.setCursor(movimiento, 0);
lcd.print(op);
cursorPos = movimiento + 1; // Move the cursor +1
} else if (final == true && key != NO_KEY && key == '=') {
mostrarCursor = false; // Hide cursor when press '='
if (op == '+') {
resultado = num1.toFloat() + num2.toFloat();
} else if (op == '-') {
resultado = num1.toFloat() - num2.toFloat();
} else if (op == '*') {
resultado = num1.toFloat() * num2.toFloat();
} else if (op == '/') {
if (num2.toFloat() == 0) {
lcd.clear();
lcd.print("Sintax Error");
delay(2000);
lcd.clear();
num1 = "";
num2 = "";
final = false;
cursorPos = (0,0); // Reset cursor
return;
resultado = num1.toFloat() / num2.toFloat();
num3 = String(resultado, 8);
// Delete decimal
num3.remove(num3.length() - 1, 1);
while (num3.endsWith("0")) {
// Delete decimal point
if (num3.endsWith(".")) {
// Show answer
int espacios = 16 - num3.length();
lcd.setCursor(espacios, 1);
lcd.print(num3);
// Clear variables and reset flags
num1 = "";
num2 = "";
final = false;
} else if (key != NO_KEY && key == 'X') {
lcd.clear();
final = false;
num1 = "";
num2 = "";
cursorPos = 0; // Reset cursor
mostrarCursor = true; // Reset cursor when press 'X'
// Cursor flashing
if (mostrarCursor && currentMillis - lastBlinkMillis >= blinkInterval) {
lastBlinkMillis = currentMillis;
cursorVisible = !cursorVisible;
lcd.setCursor(cursorPos, 0);
if (cursorVisible) {
lcd.write('_');
lcd.write(' ');
