BATTERY CHARGING MODULE TP4056
Hello friends,
I have a new battery charging module TP4056 to recharge my 3.7v PoLi battery.i hve some doubts in it... can i recharge my 3.7v battery with this module,because in the module it say 5V USB 1A Li bttery charging,if i can recharge with this module then can this module automaticaly cut off charging process after full charge the battery and it start charging when battery in low charge...hope your help as early as possible.. Thank you friends........here i am attaching the link of the module from Ebay for your kind perusal....
http://www.ebay.com/itm/5V-Lithium-Battery-Charging-TP4056-Board-5-Volt-Mini-USB-1A-Charger-Module-DIY-/181381547369
BigBobby:
Yes, it should work.
Check out the datasheet for the IC on your board -> https://dlnmh9ip6v2uc.cloudfront.net/datasheets/Prototyping/TP4056.pdf
It takes 5V input to charge a LiPo up to 4.2V.
thank you friend thanks for your help...so i hope it will do start and stop charging automaticaly too..
Yes, the first page of the datasheet in the Features section:
·Automatic Recharge
·C/10 Charge Termination
Your LiPo probably is ok with 1A charge current, but it'd be best to check as LiPos do exist that require lower charge currents.
BigBobby:
·Automatic Recharge
thank you friend......thanks for clear my doubts completely....
