Beginner problem help
Envoi en cours : D0A9BE2A-3DB3-4BE1-9CC6-A06A78D2ADF6.jpeg…
Hi everyone I’m really a beginner and here’s my problem
I have a arduino uno r3 the clone
I have the ch341 installed
And servomoteur the sg90
I used a example arduino program to try first
And the wires are correct
I even tried with different servomoteur and all of them doesn’t work
So if you’re see where is the problem tell me pls
I need your help as soon as possible
Please read this post and consider editing your question accordingly: How to get the best out of this forum - Using Arduino / Installation & Troubleshooting - Arduino Forum
You will get help faster if you format your question correctly.
Welcome to the forum.
Could you disconnect the servo motor ? Disconnect it completely.
Then try to blink the led at pin 13, then try to send a message to the Serial Monitor.
You forgot to specify what the problem is :wink:
Hello ferielmeg
Check this connection.
grafik
Did you connect the servo to pin named VIN ?
