Best GPS module
I am working on a project where I need to find the distance between two arduinos. I was attempting to do this with RF transceivers and have found that method will not work. I now want to try to solve my project with GPS modules and the tiny++ GPS library. I need the GPS to have a range of 50 to 200 meters. What is the best GPS module for this task?
GPS modules do not 'communicate', they receive signal from satellites. For what you want to do, you need a GPS module and an RF transceiver and an Arduino at each location. Or, Arduinos or other processors that have GPS and RF integrated.
There is not much difference between the latest GPS modules, as the accuracy is limited by the GPS system: +/- 2 meters at very best, with a clear, unobstructed view of the sky.
Start with two of any of them (plus two Arduinos) and see if it works out for the project. TinyGPS++ has a function for calculating the distance between two GPS locations.
Hello,
I work with SIMCOM 7080G (global coverage) and 7600G (Idem).
Both work fine and have GPS functionality.
7600 series is very complete, @ 38 USD aprox for the board that includes the SimCom module plus regulator and other components. But is not a high energy saver.
Coverage is by far more complete in the bands it uses.
7080 series is NBIoT, has excellent energy saving capabilities.
Cost about 20 to 22 USD.
But coverage is not so complete, so if you need to implement your solution in areas where you are unsure of NBIoT coverage, take care. For instance, in South America Uruguay has excellent NB coverage, Argentina and Brasil fairly good but far from 100% areas.
Last... Look at:
A in wich countries you will need to deploy,
B your energy situation,
C if you will go with a board look at AND Technology they have breakout boards well done, and you dont solder components. There are also very well done PCIE boards from other providers.
D If you will go with your own pcb you can work with the SimCom (or other) modules.
Hope this helps,
Kind regards,
Horacio
Thank you all for the advice and recommendations. What GPS module has good coverage in the United States?
All of them.
For US I would buy a couple of breakout boards from AND-Technologies to start prototyping.
If you only need US, i think the SIM7080A is a version that is optimized specifically for the North American region. This module supports fewer bands and many scans like those used in AT+COPS ar quicker, because the module has fewer bands to scan.
I do not have experience in USA module version, so double check if "A" suffix is correct.
SimCom has an excellent support, so you will have access to all information, firmwares, and tools you will need.
They also will provide you an excellent tool called SIMComSPT. An USB driven terminal to experiment an fine tuning your AT commands that is a breeze. They are now on version V3.7
Best luck !
All the Arduino hobby suppliers in the U.S. have simple, inexpensive GPS breakouts, many of which required no programming, and have good getting started guides. Examples include Pololu, Adafruit, Sparkfun, PiMoroni, plus Amazon and eBay from overseas, with little to no guidance.
