Hi all. I'm doing with wiring now. I build many projects, such as, arduino car, self balancing robot, micro quadcopter and F350 DJI Arduino drone.
I see that using thick and thin wire determines the power supply flows of a circuit. I also tried to shorten and lengthen the wires. Both of them determines the flows of power in a circuit.
Other cases I found that: A wrong choice of a certain wire causes the heat of the wire and the components in a circuit.
Conclusion (based on my experiment):
Thick and thin wires being used
Short and long wires being used
(Please let me know further if I'm wrong the conclusion above).
As a newbie, I'm lack of wires knowledge. I use AWG and ribbon wires in Arduino projects. I see that wires determines the resistance of a power flows in a circuit. The longer means the bigger resistance or vice verse.
But, It is impossible for me to buy all types of wires to see - which one is for A projects.
I'm absolutely sure many experts here have known precisely the types of wires being used in each projects. Okay, let me go to the point.
In related to micro (diy) Arduino drone, say, frame 114mm drone, what type of wires should I use for 114mm micro drone to optimize the power flows? I prefer using AWG in this case since it works better.
