Hi everyone, im running ubuntu and my board is functional (ive loading the 1.0.7 library) for basic examples like the blinking LED. I wanted to update to the latest github repo libraries so I could test out the given Bluetooth examples.
However, when trying to use this updated github repo, I get the following error when trying to test the same example:
Sketch uses 47,716 bytes (30%) of program storage space. Maximum is 155,648 bytes.
Starting download script...
!! BLE firmware version is not in sync with CurieBLE library !!
Set Programmer to "Arduino/Genuino 101 Firmware Updater"
Update it using "Burn Bootloader" menu An error occurred while uploading the sketch
Note, that while I was using 1.0.7 default code, this program (the blinking LED) one, used only 11% of the program storage space, and the sketch uploaded successfully.
Yes that is why the error is perplexing...reverting back to the 1.0.7 libraries gives me what I would expect for the blinking LED program:
Sketch uses 18,644 bytes (11%) of program storage space. Maximum is 155,648 bytes.
SUCCESS: Sketch will execute in about 5 seconds.
It seems that the problem is with the libarc32drv_arduino101.a file in the "variants" folder. Has anyone else had problems with this when using the 2.0.0 libraries?
