blinking LED with one capacitor oscillator circuit
I'm trying to make an LED blink without using a microcontroller or two transistor oscillator circuit. Basically with one capacitor, transistor (2N3904), LED and resistors, but i cant make it blink.
I found on youtube this video about a single transistor oscillator circuit where, for how much I was able to understand, is relayed on the resistance of the transistor and the "braking" point of the component or something like this, but I'm not shore if the source of the video is reliable. Can somebody check it and say if is possible to make an oscillator circuit with one capacitor and transistor and is there any other method to make it blink? here is the link to the video:
Thx
BorislavLukanov:
Wrong forum.
why? where should I post the question?
This is an Arduino funded forum (= no advertising or spam, just data mining).
IMHO all questions should be arduino related.
Leo..
ok, thx, I saw "general electronics" so I presupposed that is for all kinds of electronics.
Where should I put the question?
Why not comment on the video. Tell them that you don't know much about electronics but you would like to accuse them of being unreliable.
You can make a single transistor oscillator/LED blinker with a resistor, capacitor and a unijunction transistor (UJT). Search google images for "unijunction transistor relaxation oscillator"
Or a two transistor multivibrator.
Ok, great! Thx, I'll youtube it hehe
Wawa:
IMHO this is very related to Arduino - Arduino alone does very little without other electronic. This is nice example of "strange" behavior that can be used for an Arduino project or may lead to an unexpected failure if unknown.
Here is some explanation of the circuit.
The old-school answer to this question is "use a unijunction transistor relaxation oscillator". I've
never seen a unijunction transistor, even way back when, I doubt you'll find one these days!
Unijunction Transistor: A device that was rare when it existed... but totally forgotten when the LM555 came along.
I still have a few... but I would never use one in a new design... even a single design. Its never a good idea to design with "unobtanium".
I think you can jerry-rig a UJT replacement with two transistors.
The circuit for the ops flasher is
http://www.cappels.org/dproj/simplest_LED_flasher/Simplest_LED_Flasher_Circuit.html
Looks like it needs a fair bit of tuning, uses the avalanche voltage of a 2N2222
Tom... :slight_smile:
You are missing the point: the links claim ANY common BJT can be used this way - provided voltage is high enough. "Negative resistance" and quantum tunneling is involved, quite interesting. I will definitely try if and how this works when I get time.
ANY common BJT
No such thing these days, use parametric search on any of the reputable semiconductor suppliers web sites and there is just about a different semi for every application.
In the good old days, (showing my age), it was a handful of different semiconductors that were readily available that had to do most of your projects.
LM555, OC44, OC70, 2N3055, BC546 to 549, BC556 to 559, TIP31 and 32, LM741, LM3900, LM78XX, LM723, LM380
Memories.... like the corners... etc etc etc
Tom.... :slight_smile: :slight_smile: :slight_smile:
The reverse biased EB junction would normally work like a zener diode due to its high doping
concentration (in the emitter at least). It won't be optimized for negative resistance behaviour though,
and over driving the junction backwards is a very easy way to fry a BJT, so keep the current limited.
I've thought to an idea to test if will work to use a NPN mosfet for discharging the capacitor connecting the gait of the mosfet to the positive side of the capacitor, but i must do the math for the voltage levels in order to close the mosfet when reached the voltage needed and also there are some additional things for the mosfet so it can open when the voltage is low (a resistor or something like this), but definitely I'll try to find a UJT transistor, sounds fun hehe
Tested and it WORKS. I used unknown NPN BJT (fake LM35), circuit from link in post #9 and the LED is flashing nicely. 9V was not enough but adding one AAA to get 10.5V made it. There is about 9.8 V over the cap and around 8.2V CE voltage (measured by DMM, changing quickly; LED blink much slower when measuring the transistor).
