Bluetooth upload to pro mini working
Hello i know there is a few working ways to do this already out there but this is the first one that i know of that are based on a really cheap module(2-3usd), and require no modification on the module.
This is the module, the chip on there is a bk3231:
All you need to make a Bluetooth pro mini upload adapter is a few components you most likely already have around 4 10k resistors a npn transistor a 0,1uf cap pin header and some prototype board.
This bt module have a mcu-int pin that go high when the bt module connects with something, this is what i use to reset the pro mini.
first you need to set the baud rate just connect the module to whatever serial module you prefer, if its a 3.3v level connect directly if not use voltage divider on the rx pin on the bt module.
Set the serial monitor for 9600(standard speed from factory) and cl&nr and write AT + BAUD7 to set the baud rate to 57600 (programming speed for pro mini)(tx on bt to rx on serial....)
After that just connect it all up like this:
I have tried this on 3.3v pro mini and 5v and both are working.
This is mostly based on trial and error error error... but its working i have uploaded maybe 50 times with it so far.
This is how i connected it all up maybe not the best looking way but a good first try.
The angled pins are for vcc, the pro mini im using have a protection diode so i had to bypass that.
some pro mini have it some do not, and some have the pin order completely reversed so take care when you connect it all up.
(I have a small led on the mcu-int, this is not really needed and is not in the schematic)
So best of luck and if you try this please let me know how it goes and if you have ideas abut improvements.
Very cool!
Where do I buy that BT-module? Du you have a link?
Thanks.
// Per.
What software do you use to upload?
Here is one, you might find one cheaper if you look around a bit:
http://www.aliexpress.com
I am using arduino-1.6.5-r2 to upload, but any newer version should be OK
swe-dude:
But at pc side, do you have a bluetooth device in usb?
mart256:
I rather suspect he could be using the Laptop/PC's built in Bluetooth.
I would not mind something like this for an ATTiny85...
aisc:
Not possible as I understand it. The bluetooth is uploading the sketch to the Pro Mini via serial. You can do this with an atmega328 because it has already been programmed with a bootloader. You can't have a bootloader on an attiny85, not enough ram/flash/whatever. So attiny85 can only be programmed via SPI, which the bluetooth module cannot do.
However, there are some attiny chips, such as the '841, which can be programmed with a bootloader and then subsequently sketches can be uploaded via serial.
Paul
If someone had the Bluecore devkit from CSR, a firmware could be written that made the Bluetooth-module look like an AVRISP or similar device, and through that, program the chip. Having the SDK for the Bluetooth-module opens up an extreme amount of possibilities, as there is much power in that ARM SOC they are using. Heck, even no need for the Attiny if you go that far!
PaulRB:
Really? Confusion reigns....
Then what am I doing when I "burn bootloader" to the ATTiny85 before I use an Uno as ISP to upload a sketch to the ATTiny85?
I know it sets the fuses, but I thought I was also burning the bootloader..... no?
Zapro:
And the project runs on....?
We are discussing using the Bluetooth module as a tool not as the mcu.
aisc:
Just the fuses. From this page:
Note this doesn’t actually burn a bootloader onto the board; you’ll still need to upload new programs using an external programmer.
PaulRB:
Noted - Thanks.
To OP: Which OS are you using? I tried this with the same module on Mac OS X, and i cannot get it to work.
It pulses the reset-pin but i get the response: avrdude: stk500_recv(): programmer is not responding
// Per.
I have tried this on win 7 and 8.1, i have never used os x, so im afraid im wont be mutch help there, I guess you have already double and triple checked the Connections but check that the Connection is like in the diagram one more time. and make sure you have the vcc bypass in Place if you have a pro mini with protection diode, the module will light up anyway but without the vcc bypass it wont work.
Another thing to think abaut, atleast for me i get 2 serial ports when i connect to this over Bluetooth and the annoying part is sometimes its the higher number of the 2 and sometimes the lower one that is the port for uppload....
mayby a Picture of the setup will help me thing of something!?
//s
