Out of 4 connecting to 1 sensor is having power issue, like the sensor and the esp32-c6 temperature is becoming very high when connected to power supply and I am disconnecting it right away... I am unable to detect the issue about this 1 sensor issue...
And when it comes to the other three sensors, I tried wirescan example [the first example that I use to check the i2c connections]. But for debugging I have added a serial print address before the line of wire begin transmission for all addresses in the for loop of the example. And then I connected the sensors to the i2c pins... the scan is like 1234.....20 and that's it... Stopping at 20 and nothing in serial monitor... just thats it... If not connected, the scan is working fine... but when sensors are connected, everything becoming unresponsive.
Sounds like wiring or soldering error. Or wrong supply voltage.
If you don't post your wiring and the specific sensor module you have, it's about impossible to help.
You have to post information about your problem. Very few people here have crystal balls.
We have not seen actual wiring, power supplies, neither code.
