Problem with BNO055 output values
Hello, guys! My name is Luis, and I have some experience with coding and Arduino. I'm trying to program the BNO055 for a rocket flight computer, but when I plug in the power to my Arduino Uno Minima R4, the output values of the sensor are all 0. This also happens in the example given in the Adafruit library (#include <Adafruit_BNO055.h>). I tried to search online, but I can't understand what's going on. If someone could help me, I would be very grateful.
This is the code from the library:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <utility/imumaths.h>
/* This driver uses the Adafruit unified sensor library (Adafruit_Sensor),
   which provides a common 'type' for sensor data and some helper functions.
   To use this driver you will also need to download the Adafruit_Sensor
   library and include it in your libraries folder.
   You should also assign a unique ID to this sensor for use with
   the Adafruit Sensor API so that you can identify this particular
   sensor in any data logs, etc.  To assign a unique ID, simply
   provide an appropriate value in the constructor below (12345
   is used by default in this example).
   Connections
   Connect SCL to analog 5
   Connect SDA to analog 4
   Connect VDD to 3.3-5V DC
   Connect GROUND to common ground
   History
   2015/MAR/03  - First release (KTOWN)
/* Set the delay between fresh samples */
uint16_t BNO055_SAMPLERATE_DELAY_MS = 100;
// Check I2C device address and correct line below (by default address is 0x29 or 0x28)
//                                   id, address
Adafruit_BNO055 bno = Adafruit_BNO055(55, 0x28, &Wire);
void setup(void)
  while (!Serial) delay(10);  // wait for serial port to open!
  Serial.println("Orientation Sensor Test"); Serial.println("");
  /* Initialise the sensor */
  if (!bno.begin())
    /* There was a problem detecting the BNO055 ... check your connections */
    Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
    while (1);
void loop(void)
  //could add VECTOR_ACCELEROMETER, VECTOR_MAGNETOMETER,VECTOR_GRAVITY...
  sensors_event_t orientationData , angVelocityData , linearAccelData, magnetometerData, accelerometerData, gravityData;
  bno.getEvent(&orientationData, Adafruit_BNO055::VECTOR_EULER);
  bno.getEvent(&angVelocityData, Adafruit_BNO055::VECTOR_GYROSCOPE);
  bno.getEvent(&linearAccelData, Adafruit_BNO055::VECTOR_LINEARACCEL);
  bno.getEvent(&magnetometerData, Adafruit_BNO055::VECTOR_MAGNETOMETER);
  bno.getEvent(&accelerometerData, Adafruit_BNO055::VECTOR_ACCELEROMETER);
  bno.getEvent(&gravityData, Adafruit_BNO055::VECTOR_GRAVITY);
  printEvent(&orientationData);
  printEvent(&angVelocityData);
  printEvent(&linearAccelData);
  printEvent(&magnetometerData);
  printEvent(&accelerometerData);
  printEvent(&gravityData);
  int8_t boardTemp = bno.getTemp();
  Serial.print(F("temperature: "));
  Serial.println(boardTemp);
  uint8_t system, gyro, accel, mag = 0;
  bno.getCalibration(&system, &gyro, &accel, &mag);
  Serial.print("Calibration: Sys=");
  Serial.print(system);
  Serial.print(" Gyro=");
  Serial.print(gyro);
  Serial.print(" Accel=");
  Serial.print(accel);
  Serial.print(" Mag=");
  Serial.println(mag);
  Serial.println("--");
  delay(BNO055_SAMPLERATE_DELAY_MS);
void printEvent(sensors_event_t* event) {
  double x = -1000000, y = -1000000 , z = -1000000; //dumb values, easy to spot problem
  if (event->type == SENSOR_TYPE_ACCELEROMETER) {
    Serial.print("Accl:");
    x = event->acceleration.x;
    y = event->acceleration.y;
    z = event->acceleration.z;
  else if (event->type == SENSOR_TYPE_ORIENTATION) {
    Serial.print("Orient:");
    x = event->orientation.x;
    y = event->orientation.y;
    z = event->orientation.z;
  else if (event->type == SENSOR_TYPE_MAGNETIC_FIELD) {
    Serial.print("Mag:");
    x = event->magnetic.x;
    y = event->magnetic.y;
    z = event->magnetic.z;
  else if (event->type == SENSOR_TYPE_GYROSCOPE) {
    Serial.print("Gyro:");
    x = event->gyro.x;
    y = event->gyro.y;
    z = event->gyro.z;
  else if (event->type == SENSOR_TYPE_ROTATION_VECTOR) {
    Serial.print("Rot:");
    x = event->gyro.x;
    y = event->gyro.y;
    z = event->gyro.z;
  else if (event->type == SENSOR_TYPE_LINEAR_ACCELERATION) {
    Serial.print("Linear:");
  else if (event->type == SENSOR_TYPE_GRAVITY) {
    Serial.print("Gravity:");
  else {
    Serial.print("Unk:");
  Serial.print("\tx= ");
  Serial.print(x);
  Serial.print(" |\ty= ");
  Serial.print(y);
  Serial.print(" |\tz= ");
  Serial.println(z);
There are a lot of pins, please post an annotated schematic showing exactly how it is wired, be sure to show power, ground, and power sources. Also links to the technical information on the hardware items. I do not know what sensor you are using so I am assuming it is the Adafruit BNO055 device. Your processor is a Renesas RA4M1 microcontroller which was not included in the following warning but I do not know if it is all inclusive.
"The BNO055 I2C implementation violates the I2C protocol in some circumstances. This causes it not to work well with certain chip families. It does not work well with Espressif ESP32, ESP32-S3, and NXP i.MX RT1011, and it does not work well with I2C multiplexers. Operation with SAMD51, RP2040, STM32F4, and nRF52840 is more reliable."
Thank you for the response. This is my setup, I connected my BNO055 using the STEMMA connectors. SDA on A4 and SCL to A5.
Nice picture but it does not tell me anything about the required pull up resistors the I2C needs. Adafruit has several posts on this. With the schematic there would be no guessing. What does the I2C scanner return?
Sorry for the late respond, the I2C scanner read the sensor but it seems an communication problem sensor-arduino because if I unplug everything from the Arduino the serial monitor continues to print the 0 values. I've tried to change Arduino and test the BNO055 on the UNO and NANO but in those it works correctly. Any other suggestion?
@luisaderffuic
Did you see Post No.5 ?
Yes, I've tried but it's still the same.
Seems the Minima lacks pull-ups on SCA and SDA ?
Is your BNO board a 5V device or a 3V device? (What to do depends on the answer.)
Hmmm, you have the adafruit board.
The adafruit board has pull-up resistors.
Got anything else that runs with I2C (an LCD maybe) ?
Maybe the the BNO-sketch isn't Minima-ready ?
I have just wired the BNO and nothing else so I can't say much more.
If I were over there with my o-scope we could check for activity on D18/19 sda/scl.
I have one, should I check those pins?
Yes, if you have scope - use it.
My 'thinking': if an I2C LCD library works with it but the BNO does not then my conclusion would be that the BNO library isn't "Minima ready".
Ok I'll try it.
