after following the instructions to burn a bootloader successfully at
http://www.instructables.com/id/Atmega-Standalone-Running-without-crystal-oscillat/?ALLSTEPS
i got to thinking i may consider developing a bootloader burning shield.
i looked at the schematic of the arduino uno r3 at
i found that the rx and tx indicators are directly connected to pins 10 and 11 of the atmega chip
unfortunately when i using my multimeter to verify that it turns out that the leds are not connected to the pins 10 and 11.
the reason i want to break out the pins is because most shields would cover the indicators witch is critical for verifying board response.
it is possible that i could drill holes into a blank shield board and install light pipes or some short piece of fiber optic string to bring the indicators to the top.
i would like to build a bootloader burner shield to make it easier to install boot loaders without all the complex wiring of a breadboard and then the possibility of corrupting or even burning out the chip or something bad.
thanks for the help
