I have made a button box using a matrix for the wiring. I have watched a video on Youtube that made things look easy (MAKE THIS BUTTON BOX | 32 FUNCTION w ENCODERS - YouTube) but I am confused with the code that is supplied (GitHub - AM-STUDIO/32-FUNCTION-BUTTON-BOX) as I don't have rotary encoders (didnt want them), I just have a mix of buttons and toggles.
Rewind a little.....
I have been using Simhub (https://www.simhubdash.com/) with an Arduino Uno R3 using the built in Arduino programming tool and it registered all the button presses and toggle switches fine. I decided I wanted to change the Uno for a Pro Micro board so that I could use the button box with my Xbox or PS4 but thats where I am stuck.
Back to now....
Ive got everything wired up and if I use the Simhub way of programming then all is good...except it requires you to programme what each button press is in its 'Keyboard Emulation' section. This obviously doesnt help with using the button box on my consoles as the Micro isnt actually programmed to give the key commands, its just being emulated by Simhub.
I have tried using the Sketch mentioned at the top of the post but its for a different layout so when I start changing things like a complete noob with zero coding experience I get errors when veryfing.
I would be eternally greatful if anyone could lead me down the path to sorting this out myself.
This is how I have the board programmed through Simhub (I assume this will help you guys see how things are set up):
I have used Fritzing for the first time and drawn out what I have wired up:
Code mentioned above:
//BUTTON BOX
//USE w ProMicro
//Tested in WIN10 + Assetto Corsa
//AMSTUDIO
//20.8.17
#include <Keypad.h>
#include <Joystick.h>
#define ENABLE_PULLUPS
#define NUMBUTTONS 23
#define NUMROWS 4
#define NUMCOLS 6
byte buttons[NUMROWS][NUMCOLS] = {
{0,1,2,3,4,5},
{6,7,8,9,10,11},
{12,13,14,15,16,17},
{18,19,20,21,22,23},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
// R_START (00)
{R_START_M, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CCW_BEGIN
{R_START_M | DIR_CCW, R_START, R_CCW_BEGIN, R_START},
// R_CW_BEGIN
{R_START_M | DIR_CW, R_CW_BEGIN, R_START, R_START},
// R_START_M (11)
{R_START_M, R_CCW_BEGIN_M, R_CW_BEGIN_M, R_START},
// R_CW_BEGIN_M
{R_START_M, R_START_M, R_CW_BEGIN_M, R_START | DIR_CW},
// R_CCW_BEGIN_M
{R_START_M, R_CCW_BEGIN_M, R_START_M, R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
// R_START
{R_START, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CW_FINAL
{R_CW_NEXT, R_START, R_CW_FINAL, R_START | DIR_CW},
// R_CW_BEGIN
{R_CW_NEXT, R_CW_BEGIN, R_START, R_START},
// R_CW_NEXT
{R_CW_NEXT, R_CW_BEGIN, R_CW_FINAL, R_START},
// R_CCW_BEGIN
{R_CCW_NEXT, R_START, R_CCW_BEGIN, R_START},
// R_CCW_FINAL
{R_CCW_NEXT, R_CCW_FINAL, R_START, R_START | DIR_CCW},
// R_CCW_NEXT
{R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {21,20,19,18};
byte colPins[NUMCOLS] = {7,6,5,4,3,2};
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_JOYSTICK, 32, 0,
false, false, false, false, false, false,
false, false, false, false, false);
Joystick.begin();
CheckAllEncoders();
CheckAllButtons();
