Hello, I have recently purchased an Arduino rp 2040 card for a project. found. I have at my disposal as value the values of acceleration and angular acceleration on the 3 axes and i want to have the angle of the arduino. if anyone has a solution in any form I take and thank you in advance.
For static tilt measurements, just use the accelerometer. The formula is very simple, and is given in this tutorial.
Thanks, i will try it tomorow, if i have probleme i will sent another message. ![]()
i try it and it's work so, thanks
share sketch?
u want the sketch to calculate the angle?
/* IMU.begin() - initializes the library.
IMU.accelerationSampleRate() - reads the sampling rate in Hz.
IMU.accelerationAvailable() - checks if there's data available from the IMU.
IMU.readAcceleration(Ax, Ay, Az) - reads the accelerometer, and returns the value of the x y and z axis.
IMU.gyroscopeSampleRate() - reads the sampling rate in Hz.
IMU.gyroscopeAvailable() - checks if there's data available from the IMU.
IMU.readGyroscope(Gx, Gy, Gz) - reads the accelerometer, and returns the value of the x y and z axis.
/\ all the imu fonctions
#include <Arduino_LSM6DSOX.h>
float Ax, Ay, Az;
float Gx, Gy, Gz;
float angle;
double roll = 0.00;
double pitch = 0.00;
while (!Serial)
if (!IMU.begin()) {
Serial.println("Failed to initialize IMU!");
while (1)
Serial.print("Accelerometer sample rate = ");
Serial.print(IMU.accelerationSampleRate());
Serial.println("Hz");
//read accelerometer data
if (IMU.accelerationAvailable()) {
IMU.readAcceleration(Ax, Ay, Az);
Serial.println("Accelerometer data: ");
Serial.print(Ax);
Serial.print('\t');
Serial.print(Ay);
Serial.print('\t');
Serial.println(Az);
//Calculation of the different inclinations (pitch, roll)
roll = atan2(Ay, Az) * 57.3;
pitch = atan2((-Ax), sqrt(Ay * Ay + Az * Az)) * 57.3;
//Print all the different accélration
Serial.println("Roll: ");
Serial.print(roll);
Serial.println("Pitch: ");
Serial.print(pitch);
