Calling function from setup problem
Hello
When attempting compile i'm getting "'printLCD' was not declared in this scope"
It does exist. It doesn't use any milli timers etc
Code is Someone Elses i've modified(barely). They don't say the exact library they use but im pretty sure its the same one..
Ran into another issue with attempted compile on line 53 where lcd.begin(); wasn't a valid call.
Looked up the library i was using and changed to lcd.init(); to get compile to pass.
//20x4 LCD
#include <LiquidCrystal_I2C.h> //SDA = A4, SCL = A5 Arduino https://www.arduino.cc/reference/en/libraries/liquidcrystal-i2c/
LiquidCrystal_I2C lcd(0x27, 20, 4);
int menuCounter = 0; //counts the clicks of the rotary encoder between menu items (0-3 in this case)
int menu1_Value = 0; //value within menu 1
int menu2_Value = 0; //value within menu 2
int menu2_StoredValue = 0; // STORED VALUE FOR COMPARRISSON
int menu3_Value = 0; //value within menu 3
int menu3_StoredValue = 0; // STORED VALUE FOR COMPARRISSON
int menu4_Value = 0; //value within menu 4
bool menu1_selected = false; //enable/disable to change the value of menu item
bool menu2_selected = false;
bool menu3_selected = false;
bool menu4_selected = false;
//Note: if a menu is selected ">" becomes "X".
//Defining pins
//Arduino interrupt pins: 2, 3.
const int RotaryCLK = PB3; //CLK pin on the rotary encoder
const int RotaryDT = PB4; //DT pin on the rotary encoder
const int PushButton = PB5; //Button to enter/exit menu
//Statuses for the rotary encoder
int CLKNow;
int CLKPrevious;
int DTNow;
int DTPrevious;
bool refreshLCD = true; //refreshes values
bool refreshSelection = false; //refreshes selection (> / X)
  // HE Sensor code
  // HE Sensor code
#define DETECT 2 // pin 2 for  sensor (D2)
#define ACTION 8 // pin 8 for action to do someting (A1)
  // HE Sensor code
  // HE Sensor code
const int redRELAY_PIN = 11;  //
const int greyRELAY_PIN = 12;  //
  pinMode(PB3, INPUT_PULLUP); //RotaryCLK
  pinMode(PB4, INPUT_PULLUP); //RotaryDT
  pinMode(PB5, INPUT_PULLUP); //Button
  lcd.init();///lcd.begin();  not known in library                    // initialize the lcd
  lcd.backlight();
  lcd.setCursor(0,0); //Defining positon to write from first row, first column .
  lcd.print("Menu demo");
  lcd.setCursor(0,1); //Second row, first column
  lcd.print("Rotary encoder");
  lcd.setCursor(0,2); //Second row, first column
  lcd.print("Improved version");
  delay(5000); //wait 2 sec
  lcd.clear(); //clear the whole LCD
  printLCD(); //print the static parts on the screen
  //Store states of the rotary encoder
  CLKPrevious = digitalRead(RotaryCLK);
  DTPrevious = digitalRead(RotaryDT);
  attachInterrupt(digitalPinToInterrupt(RotaryCLK), rotate, CHANGE); //CLK pin is an interrupt pin
  attachInterrupt(digitalPinToInterrupt(PushButton), pushButton, FALLING); //PushButton pin is an interrupt pin
  // HE Sensor code
  // HE Sensor code
  /// Serial.println("Hall Module Test"); ///TESTING///
  pinMode(DETECT, INPUT);//define detect input pin
  pinMode(ACTION, OUTPUT);//define ACTION output pin
  // HE Sensor code
  // HE Sensor code
  pinMode(redRELAY_PIN, OUTPUT);
  pinMode(greyRELAY_PIN, OUTPUT);
  digitalWrite(greyRELAY_PIN, LOW);//RepeatNotColourChanger
  digitalWrite(redRELAY_PIN, LOW);
  if(refreshLCD == true) //If we are allowed to update the LCD ...
    updateLCD(); // ... we update the LCD ...
    //... also, if one of the menus are already selected...
    if(menu1_selected == true || menu2_selected == true || menu3_selected == true || menu4_selected == true)
     // do nothing
      updateCursorPosition(); //update the position
    refreshLCD = false; //reset the variable - wait for a new trigger
  if(refreshSelection == true) //if the selection is changed
    updateSelection(); //update the selection on the LCD
    refreshSelection = false; // reset the variable - wait for a new trigger
void rotate()
  //-----MENU1--------------------------------------------------------------
  if(menu1_selected == true)
  CLKNow = digitalRead(RotaryCLK); //Read the state of the CLK pin
  // If last and current state of CLK are different, then a pulse occurred
  if (CLKNow != CLKPrevious  && CLKNow == 1)
    // If the DT state is different than the CLK state then
    // the encoder is rotating in A direction, so we increase
    if (digitalRead(RotaryDT) != CLKNow)
      if(menu1_Value < 9999) //we do not go above 9999
        menu1_Value++;
        menu1_Value = 0;
      if(menu1_Value < 0) //we do not go below 0
          menu1_Value = 9999;
      // Encoder is rotating B direction so decrease
      menu1_Value--;
  CLKPrevious = CLKNow;  // Store last CLK state
  //---MENU2---------------------------------------------------------------
  else if(menu2_selected == true)
      if(menu2_Value < 9999) //we do not go above 9999
        menu2_Value++;
        menu2_Value = 0;
      if(menu2_Value < 0) //we do not go below 0
          menu2_Value = 9999;
      // Encoder is rotating in B direction, so decrease
      menu2_Value--;
  //---MENU3--------------------------------------------------------------- X stop at ColourChanger
  else if(menu3_selected == true)
      if(menu3_Value < 9999) //we do not go above 9999
        menu3_Value++;
        menu3_Value = 0;
      if(menu3_Value < 1) //we do not go below 0
          menu3_Value = 9999;
      menu3_Value--;
  //---MENU4----------------------------------------------------------------START/PAUSE = HALL EFFECT TRIGGER + DECREMENT
  else if(menu4_selected == true)
    if (menu1_Value != 0)
        lcd.setCursor(1,3); //4th line, 2nd block
        lcd.print("Pause"); //text
          // HE Sensor code
          // HE Sensor code
         int HEreading = digitalRead(DETECT);// read Hall sensor
          if( HEreading == HIGH)
            menu1_Value = menu1_Value - 1;
            HEreading = LOW;
            if (menu2_Value != 0)
              if (menu2_StoredValue == 0)
                  menu2_StoredValue = menu2_Value
              menu2_Value = menu2_Value - 1;
            if (menu3_Value == 0)
             digitalWrite(redRELAY_PIN, LOW); //StopNotColourChanger
             digitalWrite(greyRELAY_PIN, HIGH);
            if (menu3_Value != 0)
              if (menu3_StoredValue == 0)
                  menu3_StoredValue = menu3_Value
              menu3_Value = menu3_Value - 1;
             digitalWrite(redRELAY_PIN, HIGH); //StopColourChanger
            delay(150); ////DELAY FOR LIMITING -1 COUNT
          // HE Sensor code
          // HE Sensor code
      if (menu1_Value == 0)///RELAY TRIGGER
        lcd.print("Start"); //text
  refreshLCD = true;
  else //MENU COUNTER----------------------------------------------------------------------------
      if(menuCounter < 3) //we do not go above 3
        menuCounter++;
        menuCounter = 0;
      if(menuCounter < 1) //we do not go below 0
          menuCounter = 3;
      // Encoder is rotating CW so decrease
      menuCounter--;
  //Refresh LCD after changing the counter's value
  refreshLCD = true;
void pushButton()
  switch(menuCounter)
     case 0:
     menu1_selected = !menu1_selected;  //we change the status of the variable to the opposite
     case 1:
     menu2_selected = !menu2_selected;
     case 2:
     menu3_selected = !menu3_selected;
     case 3:
     menu4_selected = !menu4_selected;
  refreshLCD = true; //Refresh LCD after changing the value of the menu
  refreshSelection = true; //refresh the selection ("X")
void printLCD()                                                        ///MAINMENU NAMING
  //These are the values which are not changing the operation
  lcd.setCursor(1,0); //1st line, 2nd block
  lcd.print("Rows"); //text
  lcd.setCursor(1,1); //2nd line, 2nd block
  lcd.print("Stop"); //text
  lcd.setCursor(1,2); //3rd line, 2nd block
  lcd.print("Colour"); //text
  lcd.setCursor(13,0); //1st line, 14th block
  lcd.print("cnt: "); //counts - text
void updateLCD()
  lcd.setCursor(17,0); //1st line, 18th block
  lcd.print(menuCounter); //counter (0 to 3)
  lcd.setCursor(9,0); //1st line, 10th block
  if (menu1_Value  <1000) { //hundred
    lcd.print ("0");
   if (menu1_Value  <100) { //ten
     lcd.print ("0");
   if (menu1_Value  <10) { //one
     lcd.print ("0");
   if (menu1_Value  ==0) { //zero
     lcd.print ("0");
  lcd.print(menu1_Value); //print the value of menu1_Value variable
  lcd.setCursor(9,1);
  if (menu2_Value  <1000) { //hundred
    lcd.print ("0");
   if (menu2_Value  <100) { //ten
     lcd.print ("0");
   if (menu2_Value  <10) { //one
     lcd.print ("0");
   if (menu2_Value  ==0) { //zero
     lcd.print ("0");
  lcd.print(menu2_Value); //
  lcd.setCursor(9,2);
  if (menu3_Value  <1000) { //hundred
    lcd.print ("0");
   if (menu3_Value  <100) { //ten
     lcd.print ("0");
   if (menu3_Value  <10) { //one
     lcd.print ("0");
   if (menu3_Value  ==0) { //zero
     lcd.print ("0");
  lcd.print(menu3_Value); //
  lcd.setCursor(9,3);
  lcd.print(menu4_Value); //
void updateCursorPosition()
  //Clear display's ">" parts
  lcd.setCursor(0,0); //1st line, 1st block
  lcd.print(" "); //erase by printing a space
  lcd.setCursor(0,1);
  lcd.print(" ");
  lcd.setCursor(0,2);
  lcd.print(" ");
  lcd.setCursor(0,3);
  lcd.print(" ");
  //Place cursor to the new position
  switch(menuCounter) //this checks the value of the counter (0, 1, 2 or 3)
    case 0:
    lcd.print(">");
    case 1:
    lcd.setCursor(0,1); //2nd line, 1st block
    lcd.print(">");
    case 2:
    lcd.setCursor(0,2); //3rd line, 1st block
    lcd.print(">");
    case 3:
    lcd.setCursor(0,3); //4th line, 1st block
    lcd.print(">");
void updateSelection()
  //When a menu is selected ">" becomes "X"
    lcd.print("X");
    lcd.print("X");
    lcd.print("X");
    lcd.print("X");
You have an extra closing bracket "}"...
    refreshLCD = true;
  }  // <<<< Not required
The are also a couple of ";" missing.
Make sure you have the correct library installed... there are multiple with the same name.
There are several libraries with the name LiquidCrystal_I2C. The are not all the same and code from 1 may not run in another. Those LiquidCrystal_I2C libraries are old and most are not maintained. The newest and best library for I2C LCD with the hd44780 controller (1602, 2004) is the hd44780 library by Bill Perry. The hd44780 library automatically detects the I2C address and the LCD to I2C backpack pin mapping. The library is available via the IDE library manager. It is very easy to change code written for a LiquidCrystal_I2C library to use the better hd44780 library.
Any decent way of actually finding out which library this could be? I always thought library #include names had to be unique to be added to the library browser?
Uhh i do believe that closing bracket is required for the start of the nested if statements?
Got a line you found it on? 281?
I do wish Arduino IDE has collapsable nesting like notepad++. Makes checking so much easier
!It now compiles TYVM!
Got those missing ; tyvm.
//20x4 LCD
//Defining pins
const int RotaryCLK = 2; //CLK pin on the rotary encoder
const int RotaryDT = 4; //DT pin on the rotary encoder
const int PushButton = 3; //Button to enter/exit menu
int CLKNow;
int CLKPrevious;
int DTNow;
int DTPrevious;
// HE Sensor code
// HE Sensor code
#define DETECT 5 // pin 5 for  sensor (D5)
// HE Sensor code
// HE Sensor code
  pinMode(2, INPUT_PULLUP); //RotaryCLK
  pinMode(4, INPUT_PULLUP); //RotaryDT
  pinMode(3, INPUT_PULLUP); //Button
  lcd.init();//lcd.begin(); /// not known in library  lcd.init();///                  // initialize the lcd
  lcd.backlight();
  lcd.setCursor(0, 0); //Defining positon to write from first row, first column .
  lcd.setCursor(0, 1); //Second row, first column
  lcd.setCursor(0, 2); //Second row, first column
  delay(50); //wait 1 sec
  // HE Sensor code
  // HE Sensor code
  // HE Sensor code
  // HE Sensor code
  if (refreshLCD == true) //If we are allowed to update the LCD ...
    if (menu1_selected == true || menu2_selected == true || menu3_selected == true || menu4_selected == true)
      // do nothing
  if (refreshSelection == true) //if the selection is changed
void rotate()
  if (menu1_selected == true)
        if (menu1_Value < 9999) //we do not go above 9999
          menu1_Value++;
          menu1_Value = 0;
        if (menu1_Value < 0) //we do not go below 0
          menu1_Value = 9999;
          menu1_Value--;
  else if (menu2_selected == true)
        if (menu2_Value < 9999) //we do not go above 9999
          menu2_Value++;
          menu2_Value = 0;
        if (menu2_Value < 0) //we do not go below 0
          menu2_Value = 9999;
          menu2_Value--;
  else if (menu3_selected == true)
        if (menu3_Value < 9999) //we do not go above 9999
          menu3_Value++;
          menu3_Value = 0;
        if (menu3_Value < 1) //we do not go below 0
          menu3_Value = 9999;
          menu3_Value--;
  else if (menu4_selected == true)
      lcd.setCursor(1, 3); //4th line, 2nd block
      // HE Sensor code
      // HE Sensor code
      if ( HEreading == HIGH)
        HEreading = LOW;
            menu2_StoredValue = menu2_Value;
            menu3_StoredValue = menu3_Value;
      // HE Sensor code
      // HE Sensor code
    refreshLCD = true;
      if (menuCounter < 3) //we do not go above 3
        menuCounter++;
        menuCounter = 0;
      if (menuCounter < 1) //we do not go below 0
        menuCounter = 3;
        menuCounter--;
refreshLCD = true;
void pushButton()
  switch (menuCounter)
    case 0:
    case 1:
    case 2:
    case 3:
  delay(100); /// STOPS DEBOUNCING!!!
  lcd.setCursor(1, 0); //1st line, 2nd block
  lcd.setCursor(1, 1); //2nd line, 2nd block
  lcd.setCursor(1, 2); //3rd line, 2nd block
  lcd.setCursor(13, 0); //1st line, 14th block
void updateLCD()
  lcd.setCursor(17, 0); //1st line, 18th block
  lcd.setCursor(9, 0); //1st line, 10th block
  if (menu1_Value  < 1000) { //hundred
    lcd.print ("0");
  if (menu1_Value  < 100) { //ten
    lcd.print ("0");
  if (menu1_Value  < 10) { //one
    lcd.print ("0");
  if (menu1_Value  == 0) { //zero
    lcd.print ("0");
  lcd.setCursor(9, 1);
  if (menu2_Value  < 1000) { //hundred
    lcd.print ("0");
  if (menu2_Value  < 100) { //ten
    lcd.print ("0");
  if (menu2_Value  < 10) { //one
    lcd.print ("0");
  if (menu2_Value  == 0) { //zero
    lcd.print ("0");
  lcd.setCursor(9, 2);
  if (menu3_Value  < 1000) { //hundred
    lcd.print ("0");
  if (menu3_Value  < 100) { //ten
    lcd.print ("0");
  if (menu3_Value  < 10) { //one
    lcd.print ("0");
  if (menu3_Value  == 0) { //zero
    lcd.print ("0");
  lcd.setCursor(9, 3);
  lcd.setCursor(0, 0); //1st line, 1st block
  lcd.print(" ");
  lcd.print(" ");
  lcd.setCursor(0, 3);
  lcd.print(" ");
  switch (menuCounter) //this checks the value of the counter (0, 1, 2 or 3)
    case 0:
      lcd.print(">");
    case 1:
      lcd.setCursor(0, 1); //2nd line, 1st block
      lcd.print(">");
    case 2:
      lcd.setCursor(0, 2); //3rd line, 1st block
      lcd.print(">");
    case 3:
      lcd.setCursor(0, 3); //4th line, 1st block
      lcd.print(">");
    lcd.print("X");
    lcd.print("X");
    lcd.print("X");
    lcd.print("X");
Having fixed the compile problem. I'm having an issue with two things.
1: The push button seems to be bouncing weirdly. Button is NC
Partially solved but adding a delay @ line 343 (Not acceptable fix if i remember correctly)
2:When Start menu4_selected the screen/arduino freezes and becomes unresponsive. What have i forgotten...
