Great,
thanks so much for all your expertise,
I have decided to go with the Agilent units because they are bigger and size is an issue with this piece.
Do you know if i want common connection annode or cathode?
I have also ordered the Driver chips.
I will read all the tutorials you linked me to and probably get massively stuck along the way and beg for help
If you are using shift registers to drive them, then you need a common positive connection, so that would be common anode.
A shift register like the 595 is designed to sink current (connect it to ground) rather than source it (connect it to +ve).
However have you considered how many shift registers you will need? It will be two for each digit. You can reduce this by multiplexing but you will then need some anode drivers like a transistor or FET.
Before you order anything make sure you have a schematic that stands a chance of working.
are these guys not going to talk to each other?
Do i really need 2 of these driver/shifters per digit!
Can you tell me exactly what to order?
Or what driver/shifters i need to drive what i have already ordered.
Do i need resistors to each LED in the unit?
That would be amazing.
so if I want to run 36 characters I need 72 of these Driver chips?!
Blimey. If its within budget should I just buy the Maxim drivers? is that easier?
Are you aware of an LED matrix version of what Im doing that would be more economical / easier / practical? (see image in 3rd post)
I dont really mind if its matrix or starburst.
I just need the characters to be 2cm or so in height.
I was trying to avoid scrolling text, but maybe 3 pairs of these:
Sure 2416 or 0832
would be easier? But i have no idea where to buy them in UK at short notice.
An LED matrix would be more difficult to control as you then have a lot more LEDs to control. However an intelligent LED matrix would suite.
I got some of Ebay a month or two back for only £2.00 but I think they have gone now:-
DLR1414 Four-digit 5x7 LED dot matrix display module
They are about £20 new from:-
They might be too small for you.
There are other alternatives try searching the Farnell site.
There are about 10 threads here in this forum about the Sure Electronics displays; they also come in 16x24 or other layout, as they use any number of 8x8 matrix displays. Of course I also own one of them
Difficult to say what they are worth.. Read through those 10 threads....
