Hi all,
New to Arduino, but learning ![]()
I've bought 2 Arduino Uno R3 boards, and a 433Mhz receiver and transmitter.
Receiver : Aurel AC-RX
Transmitter : Aurel TX-SAW/433 s-Z
The plan is to use the transmitter to switch some remote control power outlets (Chacon, Belgium).
So I've downloaded the RCSwitch lib and examples.
For the receiver : I wired it on a breadboard, uploaded the receive example code, pressed some buttons on the remote control, and got the correct codes straight away. So far so good.
But then for the transmitter : I cannot get it to send anything. I don't think it's the wiring, I connected the transmitter pins as:
- 1-4-13 to GND of Arduino
- 15 to 5V of Arduino
- 3 to pin 4 of Arduino (using the SendDemo example)
But nothing seems to be sent. Listening with the receiver board doesn't give anything.
I tried setting up a simple serial write/read transmitter/receiver and I see a bunch of numbers pass that are mostly zero, when I connect the transmitter to the power, they become bursts of non-zero but that's it.
VirtualWire also gives nothing (when trying the receiver-transmitter code).
Both transmitter and receiver are right next to one another on the breadboard, but use the power of the Arduino they are connected to (so split power).
I do have both plugged in on the same laptop through USB (but not using the TR/RX pins on either board).
What am I doing wrong here?
Are there any sender/receiver examples I can use to simply test if I can get a simple string across? Am I lacking crucial knowledge, or do I have the wires still wrong ?
I use the serial monitor of the IDE to sniff traffic. Again, when I load the RCSwitch ShowReceivedCode example, and pressing the remote control of the Chacon, I get 'good' output.
I don't even know where to start looking ![]()
Thanks for any advice!
ds_acrx.pdf (78.4 KB)
txsaw433_usersmanual.pdf (111 KB)
