I am using an Arduino Uno with ATMega chip with my Windows 10 computer and I can't seem to find any way to get the drivers installed on the device. The device Arduino Uno does not appear in the ports in the Arduino IDE.
After going into the device manager I can see that the device has a problem as it is flagged with a yellow exclamation mark.
So I right-click on it and it and select update driver and then look for drivers in the Arduino ide driver folder.
However, it says that it can't find the driver.
I have even tried using the Arduino on a friend's computer that also has windows 10 and the drivers were installed automatically and it worked fine so it is not the Arduino. I even tried an Arduino Nano on my computer and it had the exact same problem as the Uno.
If anyone can figure out why Arduinos don't want to work on only my computer and what I can do to fix it I would be extremely thankful.
@cameronkerr
Take note of the links below that you bypassed on the way in. One of them has your answer.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Are you sure your UNO is an Arduino and NOT a different brand?
Almost certainly a clone which is why I gave the links to the OP.
It is a different brand, however, it still has the ATMega Chip so as far as I understand it should use the same drivers. I was not able to identify the brand as it was just one I have borrowed from my work. Here is a picture so if there is anything different I should be doing for this specific Arduino please let me know.
Nothing I've tried from other forum posts and Arduino help center has helped me unfortunately, this is a very bizarre case.
Nevermind, I got it to work by downloading these drivers: CH340 Drivers for Windows, Mac and Linux
Had you taken the time to read the links provided you would have got the drivers from the OFFICIAL Chinese site.
A common mistake if you don't know the boards. This is the Microcontroller, and is the same on 99.9% of the UNO & NANO clones I have seen and does not need a driver. The chip next to the USB port is the USB -> TTL interface chip, and this does require a driver. As you have found, the clone board you have has a CH340 chip, and needed a driver not supplied by Arduino. It could of also been a cp2101 chip, again needing a different driver.
Glad you got it working.
