So i am at my wits end with this as i have never had problems with boot loading before.. I made some pcbs with the chip on the subject title above and cant for the life of me upload a bootloader via arduino as isp.
I am using an arduino nano in order to do this but i get an error even when using minicore, I posted similar subject on the wrong thread so hopefully i wont get in to bother for this, Anyway this is the chip that is currently on my board:
ATMEGA328P-AU Microchip Tech | C14877 - LCSC Electronics.
I have never used these chips before as i am used to the chips on the uno ATMEGA328P U.
Whatever the difference between these two microcontrollers i just cant seem to boot load the AU version successfully!
I decided to test each pcb against each other and found two of the pcbs had 5 volts coming from the MOSI pin of the microcontroller so decided to sit those to the side although i still cannot upload the bootloader successfully, I decided to order another version the atmega chip ATMEGA328-AU which is without the P, Could it be the chips themselves due to having different signatures? I will post a picture of my schematic below which also could be the error.
ERROR:
Arduino: 1.8.13 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Users\RyanA\Downloads\arduino-1.8.13-windows\arduino-1.8.13\hardware\tools\avr/bin/avrdude -CC:\Users\RyanA\Downloads\arduino-1.8.13-windows\arduino-1.8.13\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\RyanA\Downloads\arduino-1.8.13-windows\arduino-1.8.13\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Error while burning bootloader.
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0xffff00
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
avrdude done. Thank you.
