I've just received a new (Genuine) Uno WiFi Rev2. The IDE is running Rev 1.8.8, I have V 1.6.23 of the megaAVR tool set installed and have selected "Arduino Uno WiFi Rev 2" as my board.
I have written a simple sketch to print out a table of ASCII codes so the only system calls are to;
Serial.begin()
Serial.print()
Serial.println()
delay()
Nothing too onerous there!! No libraries are explicitly included.
When I compile I get the following message/information;
Arduino: 1.8.8 (Linux), Board: "Arduino Uno WiFi Rev2, ATMEGA328"
Build options changed, rebuilding all
avr-g++: error: device-specs/specs-atmega4809: No such file or directory
exit status 1
Error compiling for board Arduino Uno WiFi Rev2.
option enabled in File -> Preferences.
Sifting through the output with "Show Verbose......" selected i found the following line;
Error while detecting libraries included by /tmp/arduino_build_966585/sketch/Sketch1.ino.cpp
This indicates something has gone wrong with your Arduino megaAVR Boards installation. To make sure it has been fully uninstalled you need to take some drastic action. Be aware this is somewhat advanced and will remove all boards you have installed via Boards Manager:
Click the link on the line following File > Preferences > More preferences can be edited directly in the file. This will open the Arduino15 (or similar name depending on OS) folder.
Delete all files and folders under the Arduino15 folder except for preferences.txt. Please be very careful when deleting things from your computer. When in doubt, back up!
(In the Arduino IDE) Tools > Board > Boards Manager
Wait for the downloads to finish.
Scroll down until you see the Arduino megaAVR Boards entry. Click on it.
Sadly no joy. Been through the whole process but still getting the same result. What I did notice, however, is that the Linux Tools file is much smaller than the Windows version (~31Mb against ~46Mb)
Even went through the whole thing as root to eliminate any permissions issues.
Development host : Network booted Raspberry Pi 3B+
IDE : Arduino 1.8.8
Target : Uno WiFi Rev 2
This configuration has worked for months (and continues to work perfectly) with a mega 2560
In order to eliminate any spurious issues I've gone right back to basics and am using the example 'blink' sketch completely unmodified.
Whenever I try to compile I receive the following error;
Arduino: 1.8.8 (Linux), Board: "Arduino Uno WiFi Rev2, None (ATMEGA4809)"
exit status 1
Sifting through the verbose output I find;
Error while detecting libraries included by /tmp/arduino_build_426734/sketch/Blink.ino.cpp
It's quite right, specs-atmega4809 doesn't exists. Changing "Registers Emulation" to ATMEGA328 makes no difference.
It was suggested that the installation of the megaAVR tools may have gone wrong so I have deleted the files from .../Arduino15/ except for preferences.txt and re-run the installation. I have also repeated this process as root to eliminate any permissions issues.
There is no virus protection running on this machine. On my Windows 10 PC which does have a full anti-virus, firewall etc protection scheme operating, It will compile and run but I get numerous warnings of "initialization discards 'volatile' qualifier" from the "getPINnCTRLregister()" macro. (which is another issue altogether, at least it compiles!!)
Any ideas anyone?
Please note, I posted this issue on the main Installation and Troubleshooting group before I found this WiFi Rev 2 specific group so apologies for the duplication.
There appears to be some big differences in the way the Linux and Windows packages are configured. If I follow this path on both machines (swapping / for \ )
