The error that it's saying is:
/usr/local/bin/arduino-cli compile --fqbn esp32:esp32:node32s --build-cache-path /tmp --output-dir /tmp/1304209601/build --build-path /tmp/arduino-build-BDCECFBB3B47DFF6C1E7CAD56523DA6A /tmp/1304209601/Untitled_2_jul10a
[info] Sketch uses 931693 bytes (71%) of program storage space. Maximum is 1310720 bytes.
[info] Global variables use 41144 bytes (12%) of dynamic memory, leaving 286536 bytes for local variables. Maximum is 327680 bytes.
Flashing with command:C:/Users/bless/.arduino-create/esp32/esptool_py/4.2.1/esptool.exe --chip esp32 --port COM3 --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size 4MB 0x1000 C:/Users/bless/AppData/Local/Temp/extrafiles456751033/Untitled_2_jul10a.bootloader.bin 0x8000 C:/Users/bless/AppData/Local/Temp/extrafiles456751033/Untitled_2_jul10a.partitions.bin 0xe000 C:/Users/bless/AppData/Local/Temp/extrafiles456751033/tools/partitions/boot_app0.bin 0x10000 C:/Users/bless/AppData/Local/Temp/arduino-create-agent3995136996/Untitled_2_jul10a.bin
esptool.py v4.2.1
Serial port COM3
Connecting....
Chip is ESP32-D0WD-V3 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: e4:65:b8:20:87:ac
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
WARNING: Failed to communicate with the flash chip, read/write operations will fail. Try checking the chip connections or removing any other hardware connected to IOs.
Configuring flash size...
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x000f4fff...
Compressed 17472 bytes to 12125...
A fatal error occurred: Packet content transfer stopped (received 8 bytes)
Executing command: exit status 2
