Can't make my 4.0 tft spi 480x320 v1.1 with my esp32s3 N16R8
i am trying to make one of the examples of the TFT_eSPI library but the screen i always white (the backlight). i tried configurating the User_Setup for the driver, pins and size.
#define ILI9488_DRIVER
#define TFT_WIDTH 320
#define TFT_HEIGHT 480
(everyone told me to do the pins like that and that i dont need the miso and to set the reset to -1)
#define TFT_MOSI 11
#define TFT_SCLK 12
#define TFT_CS 10
#define TFT_DC 9
#define TFT_RST -1
but the example still doesn’t work
 Example sketch for TFT_eSPI library.
 No fonts are needed.
 Draws a 3d rotating cube on the TFT screen.
 Original code was found at http://forum.freetronics.com/viewtopic.php?f=37&t=5495
#define BLACK 0x0000
#define WHITE 0xFFFF
#include <SPI.h>
#include <TFT_eSPI.h> // Hardware-specific library
TFT_eSPI tft = TFT_eSPI();       // Invoke custom library
int16_t h;
int16_t w;
int inc = -2;
float xx, xy, xz;
float yx, yy, yz;
float zx, zy, zz;
float fact;
int Xan, Yan;
int Xoff;
int Yoff;
int Zoff;
struct Point3d
  int x;
  int y;
  int z;
struct Point2d
  int x;
  int y;
int LinestoRender; // lines to render.
int OldLinestoRender; // lines to render just in case it changes. this makes sure the old lines all get erased.
struct Line3d
  Point3d p0;
  Point3d p1;
struct Line2d
  Point2d p0;
  Point2d p1;
Line3d Lines[20];
Line2d Render[20];
Line2d ORender[20];
  tft.init();
  h = tft.height();
  w = tft.width();
  tft.setRotation(1);
  tft.fillScreen(TFT_BLACK);
  cube();
  fact = 180 / 3.14159259; // conversion from degrees to radians.
  Xoff = 240; // Position the centre of the 3d conversion space into the centre of the TFT screen.
  Yoff = 160;
  Zoff = 550; // Z offset in 3D space (smaller = closer and bigger rendering)
  // Rotate around x and y axes in 1 degree increments
  Xan++;
  Yan++;
  Yan = Yan % 360;
  Xan = Xan % 360; // prevents overflow.
  SetVars(); //sets up the global vars to do the 3D conversion.
  // Zoom in and out on Z axis within limits
  // the cube intersects with the screen for values < 160
  Zoff += inc;
  if (Zoff > 500) inc = -1;     // Switch to zoom in
  else if (Zoff < 160) inc = 1; // Switch to zoom out
  for (int i = 0; i < LinestoRender ; i++)
    ORender[i] = Render[i]; // stores the old line segment so we can delete it later.
    ProcessLine(&Render[i], Lines[i]); // converts the 3d line segments to 2d.
  RenderImage(); // go draw it!
  delay(14); // Delay to reduce loop rate (reduces flicker caused by aliasing with TFT screen refresh rate)
void RenderImage( void)
  // renders all the lines after erasing the old ones.
  // in here is the only code actually interfacing with the OLED. so if you use a different lib, this is where to change it.
  for (int i = 0; i < OldLinestoRender; i++ )
    tft.drawLine(ORender[i].p0.x, ORender[i].p0.y, ORender[i].p1.x, ORender[i].p1.y, BLACK); // erase the old lines.
  for (int i = 0; i < LinestoRender; i++ )
    uint16_t color = TFT_BLUE;
    if (i < 4) color = TFT_RED;
    if (i > 7) color = TFT_GREEN;
    tft.drawLine(Render[i].p0.x, Render[i].p0.y, Render[i].p1.x, Render[i].p1.y, color);
  OldLinestoRender = LinestoRender;
// Sets the global vars for the 3d transform. Any points sent through "process" will be transformed using these figures.
// only needs to be called if Xan or Yan are changed.
void SetVars(void)
  float Xan2, Yan2, Zan2;
  float s1, s2, s3, c1, c2, c3;
  Xan2 = Xan / fact; // convert degrees to radians.
  Yan2 = Yan / fact;
  // Zan is assumed to be zero
  s1 = sin(Yan2);
  s2 = sin(Xan2);
  c1 = cos(Yan2);
  c2 = cos(Xan2);
  xx = c1;
  xy = 0;
  xz = -s1;
  yx = (s1 * s2);
  yy = c2;
  yz = (c1 * s2);
  zx = (s1 * c2);
  zy = -s2;
  zz = (c1 * c2);
// processes x1,y1,z1 and returns rx1,ry1 transformed by the variables set in SetVars()
// fairly heavy on floating point here.
// uses a bunch of global vars. Could be rewritten with a struct but not worth the effort.
void ProcessLine(struct Line2d *ret, struct Line3d vec)
  float zvt1;
  int xv1, yv1, zv1;
  float zvt2;
  int xv2, yv2, zv2;
  int rx1, ry1;
  int rx2, ry2;
  int x1;
  int y1;
  int z1;
  int x2;
  int y2;
  int z2;
  int Ok;
  x1 = vec.p0.x;
  y1 = vec.p0.y;
  z1 = vec.p0.z;
  x2 = vec.p1.x;
  y2 = vec.p1.y;
  z2 = vec.p1.z;
  Ok = 0; // defaults to not OK
  xv1 = (x1 * xx) + (y1 * xy) + (z1 * xz);
  yv1 = (x1 * yx) + (y1 * yy) + (z1 * yz);
  zv1 = (x1 * zx) + (y1 * zy) + (z1 * zz);
  zvt1 = zv1 - Zoff;
  if ( zvt1 < -5) {
    rx1 = 256 * (xv1 / zvt1) + Xoff;
    ry1 = 256 * (yv1 / zvt1) + Yoff;
    Ok = 1; // ok we are alright for point 1.
  xv2 = (x2 * xx) + (y2 * xy) + (z2 * xz);
  yv2 = (x2 * yx) + (y2 * yy) + (z2 * yz);
  zv2 = (x2 * zx) + (y2 * zy) + (z2 * zz);
  zvt2 = zv2 - Zoff;
  if ( zvt2 < -5) {
    rx2 = 256 * (xv2 / zvt2) + Xoff;
    ry2 = 256 * (yv2 / zvt2) + Yoff;
  } else
    Ok = 0;
  if (Ok == 1) {
    ret->p0.x = rx1;
    ret->p0.y = ry1;
    ret->p1.x = rx2;
    ret->p1.y = ry2;
  // The ifs here are checks for out of bounds. needs a bit more code here to "safe" lines that will be way out of whack, so they don't get drawn and cause screen garbage.
// line segments to draw a cube. basically p0 to p1. p1 to p2. p2 to p3 so on.
void cube(void)
  // Front Face.
  Lines[0].p0.x = -50;
  Lines[0].p0.y = -50;
  Lines[0].p0.z = 50;
  Lines[0].p1.x = 50;
  Lines[0].p1.y = -50;
  Lines[0].p1.z = 50;
  Lines[1].p0.x = 50;
  Lines[1].p0.y = -50;
  Lines[1].p0.z = 50;
  Lines[1].p1.x = 50;
  Lines[1].p1.y = 50;
  Lines[1].p1.z = 50;
  Lines[2].p0.x = 50;
  Lines[2].p0.y = 50;
  Lines[2].p0.z = 50;
  Lines[2].p1.x = -50;
  Lines[2].p1.y = 50;
  Lines[2].p1.z = 50;
  Lines[3].p0.x = -50;
  Lines[3].p0.y = 50;
  Lines[3].p0.z = 50;
  Lines[3].p1.x = -50;
  Lines[3].p1.y = -50;
  Lines[3].p1.z = 50;
  //back face.
  Lines[4].p0.x = -50;
  Lines[4].p0.y = -50;
  Lines[4].p0.z = -50;
  Lines[4].p1.x = 50;
  Lines[4].p1.y = -50;
  Lines[4].p1.z = -50;
  Lines[5].p0.x = 50;
  Lines[5].p0.y = -50;
  Lines[5].p0.z = -50;
  Lines[5].p1.x = 50;
  Lines[5].p1.y = 50;
  Lines[5].p1.z = -50;
  Lines[6].p0.x = 50;
  Lines[6].p0.y = 50;
  Lines[6].p0.z = -50;
  Lines[6].p1.x = -50;
  Lines[6].p1.y = 50;
  Lines[6].p1.z = -50;
  Lines[7].p0.x = -50;
  Lines[7].p0.y = 50;
  Lines[7].p0.z = -50;
  Lines[7].p1.x = -50;
  Lines[7].p1.y = -50;
  Lines[7].p1.z = -50;
  // now the 4 edge lines.
  Lines[8].p0.x = -50;
  Lines[8].p0.y = -50;
  Lines[8].p0.z = 50;
  Lines[8].p1.x = -50;
  Lines[8].p1.y = -50;
  Lines[8].p1.z = -50;
  Lines[9].p0.x = 50;
  Lines[9].p0.y = -50;
  Lines[9].p0.z = 50;
  Lines[9].p1.x = 50;
  Lines[9].p1.y = -50;
  Lines[9].p1.z = -50;
  Lines[10].p0.x = -50;
  Lines[10].p0.y = 50;
  Lines[10].p0.z = 50;
  Lines[10].p1.x = -50;
  Lines[10].p1.y = 50;
  Lines[10].p1.z = -50;
  Lines[11].p0.x = 50;
  Lines[11].p0.y = 50;
  Lines[11].p0.z = 50;
  Lines[11].p1.x = 50;
  Lines[11].p1.y = 50;
  Lines[11].p1.z = -50;
  LinestoRender = 12;
If somebody knows what’s going on please tell me.
I don't have a IL9488 but your GPIOs are the same as those I used with a ESP32S3 and a IL9341 and it worked OK
when using TFT_eSPI I tend to print out GPIO settings to make sure I have the user_sertup() etc correct
void setup(void) {
  //uint16_t ID = tft.readID();
  delay(2000);
  Serial.println("\n\nESP32 TFT_eSPI library  example TFT_Print_Test");
  Serial.printf("TFT_MOSI %d\n", TFT_MOSI);
  Serial.printf("TFT_MISO %d\n", TFT_MISO);
  Serial.printf("TFT_SCLK %d\n", TFT_SCLK);
  Serial.printf("TFT_CS %d\n", TFT_CS);
  Serial.printf("TFT_DC %d\n", TFT_DC);
  Serial.printf("TFT_RST %d\n", TFT_RST);
TFT_eSPI can be tricky to setup
maybe worth trying a different library, e.g. ILI9488 Arduino Library
Is the display reset connected to the reset pin on the esp32?
is there a spesific reset pin or i can choose
Does your board have 2 3.3v pins or just one? If you have 2, then it will be the pin right after the two 3.3v pins.
if you only have 1 3.3v pin then your board does not have a reset pin and so you will need to update the user_setup file and change it from -1 to a pin of your choosing.
You could do this either way but -1 tells the code that it will reset when the board resets as long as it is tied to the reset pin.
