I can't program my arduino pro mini with ftdi232 (tried 2 diffrent ftdi's). The sketch compiles fine, but when I try to upload it, it does nothing, then it says it tried 10 time and can't upload. The arduino could be bricked, but power led lights up and when I press reset button, the led does blink in correct pattern, also it doesn't heat up, so I don't tnik it is broken. Is it damaged or what?
Show us how you connected everything: post a schematic.
Also tell us every setting/option you selected.
Also have you tested your USB-serial adapters using the loop-back test?
Is the FTDI jumper set to 5V?
Jumper is set on 5V. Already tried all the processor options
When you try a processor option, give it a few cycles, it can be flaky. Also make sure the voltage selected by the processor and the FTDI are set the same.
If none of that works with the cheap clone, you may have been unlucky and got a bad one or a fake. I have a bunch and got lucky, they all work.
Are you certain the pro mini has the bootloader?
Does you FTDI board have 5 or 6 output pins?
The ftdi connector has 6 pins. How would I check if it has a bootloader
I'm out of suggestions.
The errors you posted seem to indicate a bad connection between the FTDI and the Pro mini or that the FTDI is bad.
If you soldered on the headers to both boards, I would check the solder joints.
