Hi, i am trying to build a protection circuit with DW01, i need 2 amp over-current protection. But i this chip have different variants of it. I can't figure out which one is the correct one for my specification.
Also is there a better chip to do this? I want protection and charging.
Thanks
This chip won't regulate current by itself. It only has protection in case a rogue charger is connected to it. When it does that, it measures the voltage across the MOSFETs which behave more or less like a low valued resistor when they're on. It's spec'd at 150mV nominal. So the current overload trip point depends on the characteristics of your FET in your circuit.
The complete charge circuit you describe would just have a current source and maybe voltage sensor, in line before the DW1.
Both mosfet are same, and uses single mosfet. Only difference i see is in the name of the DW01 chip. you can look at page 4 of the datasheet for this markings.
I tested the 2nd one and it cuts the output at 1A. not tested the 2nd one, but it's rated for 2A.
That chip not only protects from overcurrent, also from many other damages.
Also here i concern that chip is cutting the output power line when the discharge current is over 1A or 2A.
I don't know which of this chip variant works on which range, that i want to know.
Measured by you? Where do those numbers come from? Also if you have those modules, you can test your resistor theory (or at least possibly invalidate it), by checking the resistor values.
It's possible that the resistor is the upper part of a voltage divider internal to the DW01, but it's not clear on the internal diagram in the data sheet. But the text contradicts that idea, because it says that the protection is engaged by a 150mV between GND and CS. I think R2 is more likely just a limiter for input voltages that might otherwise damage the CS input.
