Cant upload code to Arduino anymore.
Hello!
I accidentally shorted my Arduino Uno yesterday when it was connected to my computer, and because of that my computer shut down. I booted the computer again and all the USB-ports seem to be fine, outputting power and recognizing my phone.
The problem is that I can't upload code to my Arduino anymore. I have tried with two Unos and my Nano and none of them can receive the code.
When I click on upload it uploads for a while but then I get this error message:
Arduino:1.8.7 (Windows 10), Kort:"Arduino Duemilanove or Diecimila, ATmega328P"
Sketch uses 724 bytes (2%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x1f
Problem vid uppladdning till brädan. Se http://www.arduino.cc/en/Guide/Troubleshooting#upload för förslag.
option enabled in File -> Preferences.
I have updated the drivers and reinstalled the IDE two times but without any luck. Any ideas?
You say you're trying to upload to an Uno, but you've selected a different board. And the output (out of sync errors with every resp= the same, and not 0) is consistent with attempting to upload with the wrong board selected....
DrAzzy:
With the board that I'm using that's the only thing that has worked before(from China). Here is the error message when I change it to UNO:
Arduino:1.8.7 (Windows 10), Kort:"Arduino/Genuino Uno"
Build options changed, rebuilding all
Sketch uses 724 bytes (2%) of program storage space. Maximum is 32256 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x7a
