So I'm trying to upload sketch "Blink" to a compatible Pro Mini (5V 16MHz) via a USB-TTL device (CH340G chip).
But I can't upload anything to it and it just leaves error messages.
When I simply press "Upload" button:
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/45gfg9/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf"
User configuration file is "/Users/45gfg9/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.wchusbserial1410
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xdd
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x07
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xdd
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x07
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xdd
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x77
avrdude done. Thank you.
An error occurred while uploading the sketch
When I "Upload Using Programmer": ("AVRISP mkII" for this error message, but none of the programmers work)
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
Other boards worked fine: Arduino Uno, Arduino Mega 2560, Arduino Micro, Compatible Mega 2560.
I tried to burn the bootloader, and succeeded, but nothing really changed when I upload, and error messages are the same as above.
You need a reset when the upload starts. Pressing the reset button on the mini at the right time might solve your problem. If your USB-to-TTL device has a DTR signal, you can use that instead.
sterretje:
Thank you for your help.
Yes, it has a DTR pin.
I tried to reset when the upload starts. But it doesn't work, and I got the following error message:
avrdude: ser_drain(): read error: Device not configured
avrdude: ser_send(): write error: Device not configured
avrdude: ser_recv(): read error: Device not configured
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
the selected serial port
does not exist or your board is not connected
"Upload Using Programmer" still won't work, as above.
I just tried to upload in Windows 10, and the message is a bit different from macOS version, but still can't upload.
Here's what I've got if I press reset when the upload starts.
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
avrdude: ser_send(): write error: sorry no info avail
avrdude: ser_drain(): read error: Access is denied.
avrdude: ser_recv(): read error: Access is denied.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x46
I have the same problem, that the Arduino just shuts off while resetting and is therefore losing connection to the PC... Did you find any solution? I know that it was already long ago..
