Hi, I just purchased a Osepp R4, and this is my first time using an Arduino. I'm trying to run the blink example, but I'm getting an error that says
avrdude: ser_open(): can't open device "\.\COM1": The system cannot find the file specified.
I've gone to device manager and set my port to COM1, and under Tools > Ports COM1 is selected. Also in the preferences.txt file COM1 is set to the default serial port. I've read a bunch of troubleshooting and watched videos, but I still can't upload. Please help
The ports menu isn't greyed out, and when I go to device manager, unplugging/plugging the board doesn't seemed to change anything (I'm looking under the Ports (COM & LPT) section). I'm not sure what to do. Also the board is lighting up when I plug it in, so I'm assuming that means that the cord is good.
Any yellow triangles in device manager? The board seems to use the 16U2 and should work out-of-the-box.
There are charge-only cables around, so the fact that it lights up does not mean that the cable is suitable for communication. Was the cable supplied with the board or did you buy one or did it come from an older cell-phone or ...?
