I'm just about to solder an Atmega32u4 and among other things i need a 1uF ceramic capacitor between Ucap and GND (according to the darasheet)! I just have 10f capacitors at hand so the question is, will 10uF be o.k., or could the current become to high for the atmega?
Thanks for the answers in advance!
You can follow the spec, or you can go rogue. If USB operations appear flakey with 10uF, get some 1uF caps. I keep a supply of 1uF and 10uF on hand for use with regulators.
• Ucap capacitor should be 1μF (+/- 10%) for correct operation.
• A 10μF capacitor is highly recommended on VBUS line
2.2.12 UCAP USB Pads Internal Regulator Output supply voltage. Should be connected to an external capacitor (1μF).
