Changing code for differences
i just have three cjmcu-101 sensors. i want to measure with use cjmcu-101. the code i used is for different modules. so do i have to change code or can this code work?
/* Irradiation meter using Solar Cell by Solarduino */
// Note :  Safety is very important when dealing with electricity. We take no responsibilities while you do it at your own risk.
// Note :  Irradiation meter is designed to measure and record the irradiation level for PV system performance check and feasibility study.
// Note :  Irradiation can measure and record (in SD card) instantaneous short circuit current (Isc) of panel, instantaneous Irradiation (W/m2) and daily Irradiation Energy in (W/m2/day)
// Note :  The daily Irradiation Energy is reset everyday or reset upon power outage (power supply to Arduino).
// Note :  The accuracy of the Irradiation is subject to the quality of user's solar cell and current module sensor.
// Note :  The Short Circuit Current of panel is recommended to be slightly lower or near the maximum range of current sensor for better accuracy results.
// Note :  The Irradiation is 100% subject to measured current and temperature coeffecient is neglected as it has almost negligible effect
// Note :  The temperature coefficient is neglected so that do not need additional temperature probe, furthermore 65 degree celcius under hot sun (40 degree temperature diference from STC) only performing 2.5% difference.
// Note :  The unit provides reasonable accuracy and may not be comparable with other expensive branded and commercial irradiation meter.
// Note :  All credit shall be given to Solarduino.
        /* 0- General */
        int decimalPrecision = 2;                   /* decimal places for only for current value shown in LED Display */
        /* 1- DC Current & Irradiation */
        int CurrentAnalogInputPin = A2;             // Which pin to measure Current Value
        float mVperAmpValue = 120;                  // If using ACS712 current module : for 5A module key in 185, for 20A module key in 100, for 30A module key in 66
                                                    // If using WCS current module : for 0.25A module key in 7000, for 0.5A module key in 3500, for 1.0A module key in 2000, for 2.0A module key in 1000.
        float moduleMiddleVoltage = 2500;           // key in middle voltage value in mV. For 5V power supply key in 2500, for 3.3V power supply, key in 1650 mV
        float moduleSupplyVoltage = 5000;           // supply voltage to current sensor module in mV, default 5000mV, may use 3300mV
        float currentSampleRead  = 0;               /* to read the value of a sample*/
        float currentLastSample  = 0;               /* to count time for each sample. Technically 1 milli second 1 sample is taken */
        float currentSampleSum   = 0;               /* accumulation of sample readings */
        float currentSampleCount = 0;               /* to count number of sample. */
        float currentMean ;                         /* to calculate the average value from all samples*/
        float finalCurrent ;                        /* the final current reading without taking offset value*/
        float finalCurrent2 ;                       /* the final current reading*/
        float ShortCircuitCurrentSTC = 2.9   ;      // Key in the Short Circuit Current (At STC condition) of your Solar Panel or Solar Cell. Value 9 showing 9.0A Isc Panel.
        float Irradiation = 0.00;                   /* This shows the irradiation level in W/m2.
            /* 1.1 - Offset DC Current */
            int   OffsetRead = 0;                   /* To switch between functions for auto callibation purpose */
            float currentOffset =0.00;              // to Offset deviation and accuracy. Offset any fake current when no current operates.
                                                    // the offset will automatically done when you press the <SELECT> button on the LCD display module.
                                                    // you may manually set offset here if you do not have LCD shield
            float offsetLastSample = 0;             /* to count time for each sample. Technically 1 milli second 1 sample is taken */
            float offsetSampleCount = 0;            /* to count number of sample. */
            /* 1.2 - Average Accumulate Irradiation */
            float accumulateIrradiation = 0;                          /* Amount of accumulate irradiation*/
            unsigned long startMillisIrradiation;                     /* start counting time for irradiation energy */
            unsigned long currentMillisIrradiation;                   /* current counting time for irradiation energy */
            const unsigned long periodIrradiation = 1000;             // refresh every X seconds (in seconds) Default 1000 = 1 second
            float FinalAccumulateIrradiationValue = 0;                /* shows the final accumulate irradiation reading*/
        /* 2 - LCD Display  */
        //#include<LiquidCrystal.h>                                   /*Load the liquid Crystal Library (by default already built-it with arduino solftware)*/
        //LiquidCrystal LCD(8,9,4,5,6,7);                             /*Creating the LiquidCrystal object named LCD */
        LiquidCrystal_I2C LCD(0x27, 16, 2);
        unsigned long startMillisLCD;                               /* start counting time for LCD Display */
        unsigned long currentMillisLCD;                             /* current counting time for LCD Display */
        const unsigned long periodLCD = 1000;                       // refresh every X seconds (in seconds) in LED Display. Default 1000 = 1 second
        /* 0- General */
        Serial.begin(9600);                               /* In order to see value in serial monitor */
        startMillisIrradiation = millis();                /* Record initial starting time for daily irradiation */
        //LCD.begin(16,2);                                  /* Tell Arduino that our LCD has 16 columns and 2 rows*/
        LCD.begin();
        LCD.setCursor(0,0);                               /* Set LCD to upper left corner to start display*/
        startMillisLCD = millis();                        /* Record initial starting time for LCD Display refresh rate. */
  /* 0.1- Button Function */
              int buttonRead;
              buttonRead = analogRead (0);                                    // Read analog pin A0. By default the LCD Display shield already assigned A0 as button function. Cannot change.
              /*Right button is pressed */
              if (buttonRead < 60)
              {   LCD.setCursor(0,0); LCD.print ("PRESS <SELECT>   ");      }
              /* Up button is pressed */
              else if (buttonRead < 200)
              /* Down button is pressed */
              else if (buttonRead < 400)
              /* Left button is pressed */
              else if (buttonRead < 600)
              /* Select button is pressed */
              else if (buttonRead < 800)
              OffsetRead = 1;                                                 // to activate offset when button <SELECT> is pressed
              LCD.setCursor(0,0);
              LCD.print ("INITIALIZING..... ");
              LCD.setCursor(0,1);
              LCD.print ("WAIT 5 SEC ..... ");
        if(millis() >= currentLastSample + 1 )        /* every 1 milli second taking 1 reading */
            currentSampleRead = analogRead(CurrentAnalogInputPin)-((moduleMiddleVoltage/moduleSupplyVoltage)*1024);      /* read the sample value */
            currentSampleSum = currentSampleSum + currentSampleRead ;                                         /* accumulate value with older sample readings*/
            currentSampleCount = currentSampleCount + 1;                                                      /* to move on to the next following count */
            currentLastSample = millis();        /* to reset the time again so that next cycle can start again*/
        if(currentSampleCount == 1000)        /* after 1000 count or 1000 milli seconds (1 second), do the calculation and display value*/
            currentMean = currentSampleSum/currentSampleCount;                                                /* calculate average value of all sample readings taken*/
            finalCurrent = (((currentMean /1024)*moduleSupplyVoltage)/mVperAmpValue);                         /* calculate the final current (without offset)*/
            finalCurrent2 = finalCurrent+currentOffset;                                                       /* The final current */
            Irradiation = (finalCurrent2/ShortCircuitCurrentSTC*1000);
            Serial.print(finalCurrent2,decimalPrecision);
            Serial.print(" A  ");
            Serial.print(Irradiation,decimalPrecision);
            Serial.print(" W/m2  ");
            currentSampleSum =0;        /* to reset accumulate sample values for the next cycle */
            currentSampleCount=0;        /* to reset number of sample for the next cycle */
            if(OffsetRead == 1)
                currentOffset = 0;                                                             /* set back currentOffset as default first*/
                if(millis() >= offsetLastSample + 1)                                           /* offset 1 - to centralise analogRead waveform*/
                    offsetSampleCount = offsetSampleCount + 1;
                    offsetLastSample = millis();
                   if(offsetSampleCount == 2500)                                             /* need to wait awhile as to get new value before offset take into calculation.  */
                {        /* So this code is to delay 2.5 seconds after button pressed */
                  currentOffset = - finalCurrent;                                             /* to offset values */
                  OffsetRead = 0;                                                             /* until next offset button is pressed*/
                  offsetSampleCount = 0;                                                      /* to reset the time again so that next cycle can start again */
                  LCD.setCursor(0,0);
                  LCD.print ("OFFSET.....     ");
                  LCD.setCursor(0,1);
                  LCD.print ("DONE  .....     ");
         currentMillisIrradiation = millis();        /* Count the time for current */
        if (currentMillisIrradiation - startMillisIrradiation >= periodIrradiation)
            accumulateIrradiation = Irradiation/3600*(periodIrradiation/1000);                                /* for smoothing calculation*/
            FinalAccumulateIrradiationValue =  FinalAccumulateIrradiationValue + accumulateIrradiation ;
            Serial.print(FinalAccumulateIrradiationValue,decimalPrecision);
            Serial.println(" Wh/m2/day");
            startMillisIrradiation = currentMillisIrradiation ;                                               /* Set the starting point again for next counting time */
        currentMillisLCD = millis();
        if (currentMillisLCD - startMillisLCD >= periodLCD)
            LCD.setCursor(0,0);        /* Set cursor to first colum 0 and second row 1  */
            LCD.print(finalCurrent2,decimalPrecision);                                                    /* display voltage value in LCD in first row  */
            LCD.print(" A   ");
            LCD.setCursor(8,0);
            LCD.print(Irradiation,0);        /* display current value in LCD in first row */
            LCD.print(" W/m2   ");
            LCD.setCursor(0,1);
            LCD.print(FinalAccumulateIrradiationValue,0);                                                 /* display current value in LCD in first row */
            LCD.print(" Wh/m2/day        ");
            startMillisLCD = currentMillisLCD ;                                                           /* Set the starting point again for next counting time */
What happens when You run the project?
it is working but given true results are not true
What does this mean "Changing code for difference" and "it is working but given results are not true"?
Looks like the code from this webpage:
https://solarduino.com/diy-irradiation-meter-with-arduino/
The original project used a current sensor. The analog input reading was offset from zero ( analogRead() gave a value of 512 for zero current), so the input was adjusted for the offset then multiplied by a scaling factor to give the desired output units.
Since you are using a different sensor, the scaling factor and offset (if any) will change. You will have to look at the specification of the sensor to see what output voltage corresponds to a specific light level and adjust the code accordingly.
thanks for advice david. i will try
